Need a lil Help, biggiest injectors with stock fuel pump
I will be running low boost on my R, looking at maybe running 550 peak and hold with the resistor box, and obd1 p28 ecu with hondata at 5 pounds. Not sure if I should run bigger injectors or if these should be suffecent enough for the time being. I will be running stock engine including stock compression. Not really looking to drop the compression at this time, just want to make resoable power at 5 pounds for know.
Thanks for any help
Lee
Thanks for any help
Lee
O ok, but I thnk his duty cycle on the 550's was like 99% from what tuan said. Not sure if I need to go ahead and get the 720's or the 96IB's or just keep the 550's since I will only be running 5ibs and I'm sure I won't be making anywhere around the power that harry did.
Vp Special K
Jul 18, 2005 11:52 AM
yusoslo
Mar 23, 2004 01:54 PM
