MBC fitting on wastegate???
Old Jun 25, 2003 | 02:07 PM
dreweg's Avatar
Default MBC fitting on wastegate???
First off this is sceraxn im on a freinds name. Well i was having problems closing my hood b/c it was hitting the wastegate. Well i shaved as much as i could off the hood and it stll wouldnt close. The only way i can get i to close is by taking off the MBC fitting on the wastegate. My question is can i leave that fitting off? I was told to leave that open anyway if i didnt have an mbc...but i dont know about leaving a hole in the top of it. Can i plug it up with a bolt or someting? What choices do i have? Thanks
Sean
Old Jun 25, 2003 | 02:12 PM
tegasaurus's Avatar
Default Re: MBC fitting on wastegate??? (dreweg)
If you have a tial wastegate, wire the MBC into the line that goes to the back/side of the wastegate... that's what i did and it worked like a charm. My MBC was homemade with 2 fittings, spring and ball bearing, im not sure if this will help but just my .02
~good luck~
-ryan
Old Jun 25, 2003 | 02:20 PM
dreweg's Avatar
Default Re: MBC fitting on wastegate??? (tegasaurus)
Sory i didnt clarify this...i have a deltagate. Really the only thing im asking is can i leave off that fitting...or atleast plug it up? Thanks.
Sean
Old Jun 25, 2003 | 05:13 PM
dreweg's Avatar
Come on guys..help me out here. This is the only thing thats keeping me from completing my install. Thanks
Sean
Old Jun 25, 2003 | 09:13 PM
sCeRaXn's Avatar
Honda-Tech Double Platinum Member
ttt
sean
Old Jun 25, 2003 | 11:30 PM
DLOTYPER's Avatar
i ran the top open for a while,,,, then plugged it up,, i dont know the car acted the same for both, then i got smart and went with a TIAL and chucked the shitty *** deltagate,,, (shitty cannot begin to describe that)
Old Jun 26, 2003 | 07:16 AM
sCeRaXn's Avatar
Default Re: (DLOTYPER)
OK that makes me happy...now i can finally finish this ****. So what problems should i expect to run into with my shitty deltagate. Ive heard that they are shitty but ive never really heard why. I plan on getting a tial ASAP. Thanks
Sean
LSVTECTURBOTYPER
Dec 19, 2005 04:38 PM
acurar0ss
Apr 7, 2005 03:27 PM
operatic
Dec 13, 2004 03:41 PM
gdrum
Feb 8, 2004 04:53 PM
killa_lude
Oct 1, 2003 04:59 AM
