Why does my top end die off?
Old Jun 25, 2003 | 10:56 PM
roydogg's Avatar
Default Why does my top end die off?
I have a 97 accord LX auto with I/h/e 100,xxx miles. Everytime I floor it, it pulls nice through the mid range but as soon as I get towards redline it feels like its stressin the **** out of my motor. It doesn't pull like my friends stock 97 accord, his car has a nice smooth pull to redline. It feels as if I advanced the timing but you can't on obd2 accords. What could be the problem?
Thanks,
Roy
Old Jun 26, 2003 | 12:01 AM
J2turbo21's Avatar
Default Re: Why does my top end die off? (roydogg)
Why cant you advance the timing on your accord?Try some routine maintanence like spark plugs,wires,cap and rotor.
Old Jun 26, 2003 | 06:04 AM
roydogg's Avatar
Default Re: Why does my top end die off? (J2turbo21)
I can't advance my timing cause it advances itself at wot.I'll try a routine maintenence hopefully it helps .
Old Jun 26, 2003 | 10:46 AM
Fkned2003's Avatar
try cleaning your injectors with 100k+ they might be cloged and not be able to deliver the amount of fuel you need at top end.
Old Jun 26, 2003 | 06:33 PM
roydogg's Avatar
Default Re: (Fkned2003)
So I should just do a tune up and put some feul injector cleaner in the feul tank and see what happens from there.
circletrack15
Jul 23, 2017 11:15 AM
DelSolAntrax
Jan 8, 2014 04:51 PM
freezerman
May 26, 2013 10:10 PM
ThatGreenGsr
May 20, 2008 07:54 PM
Dmc1
Feb 16, 2006 04:39 PM
