Mini-Me question!
Old Jun 25, 2003 | 10:03 PM
RacinMasonC's Avatar
Default Mini-Me question!
Okay i just spent a total of 10 hours doing my mini-me fuking swap!!! 1 hr for NAPA giving me the wrong gasket, 3 hours trying to find the right socket size for all the bolts... then 1 hr for the distributor.. it was a bitch but its running fine
my timing is right, it starts up but when i rev the engine my head has a whistling noise, when i poped my hood and reved from the throttle cable i noticed it was the timing belt (we spilt some oil on the belt) could that be the whistling noise? also the head when i rev sounds a bit different the my d16a6 head (now D16z6 head) and there is NO VTEC right now, could that be why its a different noise? or could it possibly be it still has to get worked in the oil and coolant and new headgasket and stuff? please HELP!!!!
Old Jun 25, 2003 | 10:18 PM
SIRX's Avatar
Default Re: Mini-Me question! (ZiviCase)
installing a new head gasket will not make any kind of noise. Usually a whistling noise is because of a vacuum leak. check all your lines
Old Jun 26, 2003 | 05:49 AM
spooned-ek's Avatar
i just fired up a similar swap with a y7/8. I had a strange whistle the first time i touched the pedal. Could it be the IAC?
Old Jun 26, 2003 | 08:32 AM
devonic's Avatar
spooned-ek: yea you probably need to plug the vacuum line up on the back of the intake manifold, use some tube and then just screw a screw in the end of the tube, thats what i did till i put my boost guage in
Snowblindz
Oct 3, 2017 12:34 AM
949
14
Sep 19, 2010 04:57 PM
vtec lag
Honda S2000
Dec 30, 2008 07:54 AM
qhondak
Oct 25, 2008 09:20 AM
91_CRX
Apr 20, 2005 03:59 PM
