Broken Bolt in Block, HELP!
Old Jun 25, 2003 | 07:39 PM
Eggman's Avatar
Default Broken Bolt in Block, HELP!
Okay I tried to change my waterpump on my B16A and upon putting it back together one of the water pump bolts broke off inside the block. Not one bit of it was sticking out. Seems that the waterpump bolts are different sizes, by a few mm. I think I used a long one, when it should have been the shorter.
1. So first off, I used a dremel to cut a line in the bolt and use a flathead screwdriver to screw it out. Didn't work!
2. Okay, I go to the hardware store and get the special drill bits to back out the bolt. Drill a hole in the bolt then stuck the special bit in there and the freakin tip breaks off inside the bolt as I start.
3. I tried to just use a bigger drill and just drill it all out, but every bit I put in there, stops when it hits the other tip and breaks itself.
So what are my options now??
PS- Motor is out of car, sitting on the ground. If any local peeps want to help me fix this at my place, rather than me taking the whole motor to a shop, then let me know. I'd be glad to someone for their time.
Charles- Why can't I just leave things ALONE?
Old Jun 25, 2003 | 07:55 PM
poison's Avatar
Default Re: Broken Bolt in Block, HELP! (Eggman)
Ahh
That's a case by case and depends on the situation. But if the bolt is in deep enough, especially being a water pump bolt -- Hate to break bad news, but it sounds like you may need a replacement block
I would not install the water pump with a re-tapped bolt and such on the water pump, it will just end up leaking and not seal properly under extreme conditions, if anything, normal conditions.
Wish best of luck to you.
Old Jun 26, 2003 | 07:40 AM
Eggman's Avatar
Default Re: Broken Bolt in Block, HELP! (poison)
bump
Old Jun 26, 2003 | 11:23 AM
Blaze45's Avatar
Brrraaaap!
I would take a few pics an go to a local machine shop. See what they can do. They might be able to tap out the bolt/bit and rethread the hole. It might be bigger bolt though. Other then that, I would of tried an easy out first. But ya know I broke one of em too so I guess the best thing would of been to take it to machine shop in the first place... Breaking bolts sucks, I broke 3 during my swap.
Hope ya can work something out.
Blaze
Old Jun 26, 2003 | 11:25 AM
TrevorHiroshima
Guest
Posts: n/a
hmm id unnoo... my freind ian broke one of my vtec silinoid bolts into my block too.. now all i do is leak oil out of it.. and same situation as you nothing is sticking out
Old Jun 26, 2003 | 11:34 AM
94TealCivic's Avatar
Default Re: Broken Bolt in Block, HELP! (TrevorHiroshima)
I had a couple bolts broken in my head. My dad drilled it out with a bigass drill and now it needs to be re-threaded. My local tuner shop quoted me $50 to rethread it
Old Jun 26, 2003 | 12:51 PM
StyleTEG's Avatar
Default Re: Broken Bolt in Block, HELP! (94TealCivic)
Oh man, this isn't going to be fun.
I don't know how much room you have but....
if you can drill small holes on the sides of the EZ-out, you can release the pressure so that will pop out. From that point, I would see about getting something welded onto the stuck bolt so that it can safely be backed out.
I guess you wouldn't have to get the EZ out to do that, lol.
Old Jun 26, 2003 | 04:30 PM
ninety9ex's Avatar
I broke off a bolt in my block... My dad drilled a little hole in it just enough to fit a tiny phillips head screwdrver in very snugly... he then unscrewed it... that's it... I bought some new bolts from the dealership and that was it... hope you have the same luck!
Old Jun 26, 2003 | 05:19 PM
fu*kfaceC1EH2's Avatar
Default Re: Broken Bolt in Block, HELP! (ninety3EX)
yeah it's hard to help you out without seeing it, but i would use a cobalt steel drill bit, and if you can figure out what size it is, let's say a 10mm (just an example) use an 8mm bit, drill out the center of the bolt, and take your time doing it. once you get most of it drilled through the bolt, try a 'fluted' extractor if the regular extractor (E-Z out) with reverse threads doesnt work. i've never had a problem with a regular one, as long as i had one that would go into the whole just half way in... but if it doesnt, get the fluted and easily tap it with a hammer unitl it get a strong grip on the hollowed out bolt... then use an open end wrench to the extractor and you should be good. Might as well try before geting the machine shop involved. It would be a VERY good idea to still have it checked. The shop can flux it and it will show if there are ANY cracks leading into the block. AND DONT PAY $50 TO RE TAP IT.. pay 4.99 for a tap a size larger than the old bolt with the corresponding cobalt bit, and take your time re-drilling the new hole. Just my .02
Old Jun 26, 2003 | 06:02 PM
mister 5's Avatar
bump
Old Jun 26, 2003 | 06:04 PM
mister 5's Avatar
i'm a regular!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! heeheeeheeeheeeheheheee
Old Jun 27, 2003 | 12:12 AM
sparkz's Avatar
yes, 1 of the waterpump is longer then the rest. i had hte same problem too!! hahaha. im just running one less screw now with a lot of honda bond
Old Jun 27, 2003 | 07:07 AM
Eggman's Avatar
Default Re: Broken Bolt in Block, HELP! (sparkz)
Are you serious?? I am so down to do that, if it works. F*@& this B16A! Which one of your bolts are you missing? Mine is the upper left one that is all by it's lonesome from the other bolts.
Old Jun 27, 2003 | 07:24 AM
HT Chaplain's Avatar
Loved
I did the same thing but it didnt break alll the way and i was able to back it out.
Old Jun 27, 2003 | 11:06 AM
Muckman's Avatar
Moderator in Chief
Default Re: Broken Bolt in Block, HELP! (ask ^him^ about jesus! hah)
worst case scnerio: have a local machine shop drill it out and put healy coils in with same dimentions. Hell I had it done on a block which had broken motor mount bolt holes and its held up just fine.
Modified by Muckman at 3:44 PM 6/27/2003
jorge59la
Jun 18, 2008 02:57 PM
Homotor
Apr 20, 2007 02:11 PM
JDMB20TDA
Nov 20, 2006 07:09 AM
The Internet Tough Guy
13
May 17, 2006 07:18 PM
93preludes
Dec 4, 2003 01:58 PM
