where is the coolant drain bolt?
Old Jun 25, 2003 | 07:12 PM
blueeg's Avatar
Default where is the coolant drain bolt?
where is the coolant drain bolt on a '96 d16y7? is there one? a pic would be nice too. thanks
Old Jun 25, 2003 | 07:24 PM
Mjfan12's Avatar
look under the radiator. I dunno for a 96, but on 5 gens there is a wingnut on one side. This is the draing bolt nut.
Old Jun 25, 2003 | 07:35 PM
blueeg's Avatar
Default Re: where is the coolant drain bolt? (blueeg)
oops. didnt make that clear. the bolt on the engine block not the radiator.
Old Jun 25, 2003 | 08:06 PM
MaxSterling's Avatar
big *** bolt behind the headers
Old Jun 25, 2003 | 08:25 PM
PinchE NegRo's Avatar
i believe the only coolent drain bolt is on the radiator...
it should be at the very bottom either on the right or left side...
Old Jun 25, 2003 | 08:28 PM
ATS*Mark's Avatar
OG triple OG
Default Re: where is the coolant drain bolt? (EK-TUNED)
i believe there is only one on the radiator , its on the bottom right its a wingnut , if there is one on the block that would be great.
euclid's Avatar
make sure you have a new washer for the block drain bolt, it is not reusable.
Old Jan 22, 2004 | 03:34 AM
ATS*Mark's Avatar
OG triple OG
Default Re: where is the coolant drain bolt? (euclid)
where is the block drain bolt located?
Old Jan 22, 2004 | 05:03 AM
93CivicSI's Avatar
Default Re: where is the coolant drain bolt? (Hella_JDM)
Behind the headers - Giant pain in the butt to remove...
Old Jan 22, 2004 | 07:08 AM
The Internet Tough Guy's Avatar
Default Re: where is the coolant drain bolt? (93CivicSI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93CivicSI &raquo;</TD></TR><TR><TD CLASS="quote">Behind the headers - Giant pain in the butt to remove...</TD></TR></TABLE>
i think you're wrong (or you're refering to a v6 ). its on the back of the block by the oil filter. this topic came up earlier.
from a 96-98 helms manual:
also there is no mention of engine specific differences here, so i'm assuming the bolt is there for y5,y7, and y8 engines. i know for a fact that's there it is on my y8. to loosen it, try getting at it from underneath the passenger side. if you go directly under it, the axle is in the way. still a pain in the *** either way, and coolant gets everywhere, so have a beer bong like contraption up there.
Modified by jwn7 at 11:42 AM 1/22/2004
kaivorth
Honda Civic (2001 - 2005)
Oct 31, 2016 04:48 AM
lamboextreme
Sep 4, 2007 10:24 PM
ehonda1980
Aug 1, 2007 12:18 AM
ehonda1980
Jul 31, 2007 11:26 AM
aeon
Jan 1, 2004 05:02 PM
