A/C Removal HELP...
Old Jun 25, 2003 | 07:06 PM
Art Vandeleigh's Avatar
Default A/C Removal HELP...
well i am removing the AC as i type , but i was trying to remove the sunction and discharge hoses from the compressor, and while i was unbolting it it started to release gas....is this right or am i screwed?? help.
Old Jun 25, 2003 | 07:07 PM
baonest1's Avatar
Default Re: A/C Removal HELP... (Art Vandeleigh)
lol. yah. either way, you need to get rid of the gas in there.
just don't breathe it in
Old Jun 25, 2003 | 07:09 PM
Default Re: A/C Removal HELP... (baonest)
so do i just let it continue to release??
Old Jun 25, 2003 | 07:13 PM
davidnyc's Avatar
I took my car to a A/C shop for them to suction all of the refrigerant out of my car. The older-type (from the 1950's-1970's or so) refrigerant was toxic, but I think the newer stuff isn't as bad. If I were, you at the very least I would not do it in an enclosed area. But, to be safe, I would wait, go to a shop, get it taken out and then remove the A/C system safely.
Old Jun 25, 2003 | 07:15 PM
Default Re: A/C Removal HELP... (davidnyc)
well its too late for that now....i didnt think this through....i have tried to tighten the bolt back, but there is still a leak...so i guess i just let it go?? **** i feel awfull!!!
Old Jun 25, 2003 | 07:16 PM
tilt's Avatar
If you are refering to r134a, it is still toxic to breathe - just more ozone friendly. If you breathe enough of it in you can collapse and die at least thats what the can says.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by davidnyc &raquo;</TD></TR><TR><TD CLASS="quote">I took my car to a A/C shop for them to suction all of the refrigerant out of my car. The older-type (from the 1950's-1970's or so) refrigerant was toxic, but I think the newer stuff isn't as bad. If I were, you at the very least I would not do it in an enclosed area. But, to be safe, I would wait, go to a shop, get it taken out and then remove the A/C system safely.</TD></TR></TABLE>
Old Jun 25, 2003 | 07:18 PM
davidnyc's Avatar
Do a search at http://www.howstuffworks.com they may have a section on car airconditioning or do a google search on how to remove/recharge air conditioning systems.
Old Jun 25, 2003 | 07:19 PM
baonest1's Avatar
Default Re: A/C Removal HELP... (tilt)
just let it go. just lift the garage door if possible.
if you ever want to put AC back in, just get that o-ring of the screw you opened and replace it. cuz now it leaks and needs a new one.
if you want to be safe, get a fan and blow it all away into the outside.
Old Jun 25, 2003 | 07:22 PM
yeah thats what i did, big **** fan and garage door fully open. The gas has stopped, and i guess thats all it had, but the gara smells like sulphur....damn i feel sooooo bad!!!!!!!
so is that all the refridgerant that is left in the system??
Old Jun 25, 2003 | 07:26 PM
Turtle's Avatar
don't feel mad...no reason to you damn ozone killa...
Old Jun 25, 2003 | 07:27 PM
baonest1's Avatar
lol.. yah, ive been around one to many AC's when letting the gas go.
yah, that is all that is left.
but if you are taking out your heater, you have coolant lines running to the box and you need to drain the coolant from the rad and block, unless you can be very careful.
just be extra careful with the ACcompressor. any liquid you get in it will tend to seize it up, a little accidental oil or lube wont hurt it, but just dont try to clean it off with brakekleen or anything if it is dirty.
Old Jun 25, 2003 | 07:32 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by baonest &raquo;</TD></TR><TR><TD CLASS="quote">but if you are taking out your heater, you have coolant lines running to the box and you need to drain the coolant from the rad and block, unless you can be very careful.
baonest: what box are you talking about? thanks!!
I just want to get rid of the AC compressor and all the plumbing that goes with it....i didnt see any line that come from the rad or that go into the rad...please elaborate. Thanks again!!
Old Jun 25, 2003 | 07:46 PM
baonest1's Avatar
PM sent..
sorry for the confusion
hondmywrld
12
Aug 25, 2010 08:00 PM
redDAinteg
May 19, 2006 08:41 PM
menappi
Mar 30, 2005 05:56 AM
hiendgsr
Jun 29, 2004 11:16 PM
technine
Jun 7, 2002 09:40 PM
