HID question for 99 CIVIC
Old Jun 25, 2003 | 06:23 PM
SiC CiViC's Avatar
Default HID question for 99 CIVIC
if i bought hid's out of a 3.2 CL what would i need to make them work in my 99 SI
Old Jun 25, 2003 | 06:28 PM
kent's Avatar
Default Re: HID question for 99 CIVIC (SiC CiViC)
body work..
Old Jun 25, 2003 | 06:36 PM
chrisir19's Avatar
Default Re: HID question for 99 CIVIC (kent)
well first find out if the headlights are H4. You will def. need the lamps, the ballast and most of the CL wiring. The ballast should have their own power source that leads to the battery in addition to the headlight on/off signal.
Old Jun 25, 2003 | 07:01 PM
EL'ation's Avatar
You have to convert D2R base to H4 and some wiring, then you are done.
I don't think you will need the shields because it's already painted on the bulb.
Old Jun 26, 2003 | 02:43 AM
SiC CiViC's Avatar
Default Re: HID question for 99 CIVIC (EL'ation)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL'ation &raquo;</TD></TR><TR><TD CLASS="quote"> You have to convert D2R base to H4 and some wiring, then you are done.
I don't think you will need the shields because it's already painted on the bulb.</TD></TR></TABLE>
is converting them easy, can i buy something to convert it???
JDM808
Lighting
Mar 23, 2008 11:53 PM
Tellis234
Aug 19, 2007 03:29 PM
Project_EK
Feb 4, 2007 07:09 AM
slambedcivic
24
Nov 13, 2006 10:28 AM
Grease Monkey
Apr 25, 2004 08:19 AM
