Valve Cover Gasket, does it cause the car to over heat?
Old Jun 25, 2003 | 05:29 PM
slowls's Avatar
Default Valve Cover Gasket, does it cause the car to over heat?
If there is a leak on the valve cover gasket does it cause the car to overheat?
Old Jun 25, 2003 | 05:30 PM
ragejed's Avatar
Default Re: Valve Cover Gasket, does it cause the car to over heat? (slowls)
no, it causes an oil leak, and could lead to a dirty engine!
Old Jun 25, 2003 | 06:58 PM
blueeg's Avatar
yeah what he said.
Old Jun 25, 2003 | 09:26 PM
slowls's Avatar
thanks
Old Jun 25, 2003 | 10:24 PM
shamoo's Avatar
Will you make something up for me please?
Default Re: (slowls)
As said before, no. You'll just get an oil leak.
You're probably confusing it with the head gasket. Some aftermarket designs don't comform to the coolant chambers, thus causing overheating problems. Some blockguards do this too.
rovafa2002
Jul 2, 2013 07:50 AM
skate1968
10
Sep 2, 2010 04:34 AM
EJ8VTEC
Acura TSX
Nov 7, 2008 01:46 PM
Shaguar47
May 28, 2007 08:47 AM
Qwikrex
Nov 18, 2002 02:13 PM
