Where can I get a decent High Flow Cat?
Old Jun 25, 2003 | 03:20 PM
Integrity's Avatar
Default Where can I get a decent High Flow Cat?
I've already done a search so don't get all upset for me asking. I'm getting a JDM DC Sports 4-1. I know the ground clearance sucks, but I'm not going to lower the car so who cares? Since the collector on the header is 2.5", I figured I'd buy a highflow cat to make the installation easier. (I'm doing it myself) I'm also keeping the stock exhaust... so where can I find a cat that will do the trick? Thanks in advance!
Old Jun 25, 2003 | 03:42 PM
Maximus's Avatar
Default Re: Where can I get a decent High Flow Cat? (Integrity)
http://www.ipsracing.com can get you a carsound cat and http://www.aj-racing.com can hook you up with a T1R resonated test pipe.
Old Jun 25, 2003 | 03:44 PM
97jrscgsr's Avatar
i hope this helps.
http://store.hybridgarage.com/store/hgrstore.pl
they have the cat on special for now 119.99 shipped to your door.
i use the same one on my jdm 4-1 header fits great no rattling or any leak yet. perfect direct fit. give them a try.
Old Jun 25, 2003 | 03:52 PM
Edwin's Avatar
Try a Dynomax catalytic converter. Too many stories of bad Carsound catalytic converters.
Old Jun 25, 2003 | 04:33 PM
Type-Rare#1248's Avatar
Default Re: Where can I get a decent High Flow Cat? (97jrscgsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97jrscgsr &raquo;</TD></TR><TR><TD CLASS="quote">
i use the same one on my jdm 4-1 header fits great no rattling or any leak yet. perfect direct fit. give them a try. </TD></TR></TABLE>
i read their article and it only mentioned working for jdm 4-1...does anyone know whether or not it would fit for toda header?
Old Jun 25, 2003 | 05:19 PM
Integrity's Avatar
Default Re: Where can I get a decent High Flow Cat? (Type-Rare#1248)
Thanks for the help guys. 97jrscgsr... Are you still running the stock exhaust? If not, what kind of exhaust are you using?
Old Jun 25, 2003 | 05:41 PM
Asahi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97jrscgsr &raquo;</TD></TR><TR><TD CLASS="quote">i hope this helps.
I ran the same Cat when I had a JDM 4-1. Never broke and is on another car now.
Trey
Old Jun 25, 2003 | 06:59 PM
Ferrell's Avatar
Default Re: Where can I get a decent High Flow Cat? (Asahi)
Got mine from SMSP
Old Jun 26, 2003 | 03:56 AM
jond's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Asahi &raquo;</TD></TR><TR><TD CLASS="quote">I ran the same Cat when I had a JDM 4-1. Never broke and is on another car now.</TD></TR></TABLE>
The website says their cat is made from a carsound cat...
Old Jun 26, 2003 | 04:08 AM
Asahi's Avatar
Default Re: Where can I get a decent High Flow Cat? (jond)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jond &raquo;</TD></TR><TR><TD CLASS="quote">
That it is and they custom make the length just like IPS and SMSP. They used the 54006 models that are round not oval and seem to be less prone to break for me. It isn't known to flow quite as well but the difference is minimal and the fact it is stronger gave me peace of mine.
Trey
Old Jun 26, 2003 | 04:29 AM
jond's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Asahi &raquo;</TD></TR><TR><TD CLASS="quote">They used the 54006 models that are round not oval and seem to be less prone to break for me.</TD></TR></TABLE>
Anyone know why smsp doesnt use this model?
Old Jun 26, 2003 | 04:35 AM
Asahi's Avatar
Cost and flow last time I discussed this with David. I might be misrepresenting his motives so someone shoudl PM him and ask him to reply here. The 94xxx models are the ones that have seen the greatest failure rate but are also the most commonly used. The typical reson to use the 54xx vs the 94xxx was length as the 54xxx is shorter and fits on a 94-99 GSR better. You can easily use it on an R or SI or other model integra since it just requires longer tubing but for some reason isn't commonly done.
jered247
Honda Civic (2001 - 2005)
May 15, 2006 03:36 PM
Type RS
Apr 1, 2003 12:27 PM
EvoTypeR
Apr 10, 2002 05:35 AM
FusionITR
Mar 23, 2002 10:52 AM
Bbasso
Feb 16, 2002 05:50 PM
