h22a injectors
Old Jun 25, 2003 | 12:59 PM
tiaccordsh's Avatar
Default h22a injectors
I did an obd1 conversion (from obd2) and I just got around to swapping injectors. My question is, are the positive and negative wires swapped between the obd 1 injectors and obd2? onthe obd1 there are a ton of red and black wires, on obd2 there are a ton of yellow and black wires. should I assume the multiple sets of each type go together? As i have it wired now, that is not the case, and it is running like ****. However that could be any number of other reasons. Thanx in advaced.
Old Jun 25, 2003 | 02:15 PM
dfoxengr's Avatar
Default Re: h22a injectors (tiaccordsh)
they yellow/black on civic/integras/ probly running badly because the lude injectors are a higher output, what year prelude injectors are you using? because umight need resistors.
Old Jun 25, 2003 | 03:24 PM
tiaccordsh's Avatar
Default Re: h22a injectors (hybridvteceg)
I have an h22a4 (sh) and im usin 93 injectors. I swapped the wires and its runnin better, how do I know if i need resistors?
jinxster
Jun 24, 2004 02:33 PM
aesthetics82
Apr 2, 2003 05:39 AM
LSturboHB
Jan 3, 2002 02:05 PM
