quaife LSD
i have an H23 in a 93 lude. while doing a lot of engine work i'm thinking about throwing on an LSD. i've searched but i still have more questions. anyone that has a quaife...... does it make a lot of noise? how hard is the install? any pics would be greatly appreciated.
i'm a mechanical engineer, so i think i'm pretty mechanically inclined. i just don't want to get in over my head. do i need special tools or anything? is there anyone out there that's done this before? share your info
i have a quaife. Its awesome, but not very streetable. It doesnt make much noise, but it needs to be driven a certain way to be "engaged". Basically, not lifting off the gas, racing or not. Once it is, its awesome.
If you let off the gas between shifts, it wont engage properly and wont be as effective.It needs to be raced on a bit before its effective.This is a good thing for me, and keeps me sane on the streets, cuz that quaife make my lude a whole different beast!! I think you should get the Type S LSD, its cheaper, and more streetable. I wouldnt try installing it yourself unless you know what you are doing.
I have one in my 5th Gen Base and I like it.
https://honda-tech.com/zerothread?id=305341
There's a link to an imagestation album with more pictures in there but I don't think the username/password of test/test works anymore.
I love my Quaife, and wouldn't recommend anything else.....install is not bad, you DEFINATELY need a Helms, and an impact gun to get the reverse-threaded bolts off the gear is really handy.....other than that, just keep track where everything goes and do it in a clean environment. I'd say that getting the tranny out and in is 2 times as bad as putting in the quaife, so wait till you're putting in a clutch and stuff as well
Brian
Brian
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FaS4wS »</TD></TR><TR><TD CLASS="quote">i have a quaife. Its awesome, but not very streetable. It doesnt make much noise, but it needs to be driven a certain way to be "engaged". Basically, not lifting off the gas, racing or not. Once it is, its awesome.
If you let off the gas between shifts, it wont engage properly and wont be as effective.It needs to be raced on a bit before its effective.This is a good thing for me, and keeps me sane on the streets, cuz that quaife make my lude a whole different beast!! I think you should get the Type S LSD, its cheaper, and more streetable. I wouldnt try installing it yourself unless you know what you are doing.</TD></TR></TABLE>
WTF
WTF
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FaS4wS »</TD></TR><TR><TD CLASS="quote">I think you should get the Type S LSD, its cheaper, and more streetable. </TD></TR></TABLE>
Type S doesn't come with an LSD, it comes with ATTS. You're referring to the LSD in the SiR S-Spec.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Firedrake »</TD></TR><TR><TD CLASS="quote"> I'd say that getting the tranny out and in is 2 times as bad as putting in the quaife, so wait till you're putting in a clutch and stuff as well
Brian</TD></TR></TABLE>
well, i will have the tranny out since i'm sending off the block and head. this is why i was thinking about doing it now. i would like to see steps on the install if anyone knows where to find it. i may be more than capable of doing it myself, but i won't know until i know the steps involved in the switchover. all your help is greatly appreciated.
