p28 chip, p3o ecu, I know i'm retarded
Old Jun 25, 2003 | 08:46 AM
B16EJ's Avatar
Default p28 chip, p3o ecu, I know i'm retarded
will my car blow up if I put a JUN spec chip for p28 ecu's in my p30 ecu? i've already wired the knock sensor and I have a b16a3 del sol motor. has any one done this? the car is an eg coupe... 5spd if it makes a diff...
Old Jun 25, 2003 | 08:48 AM
976's Avatar
976
New User
Default Re: p28 chip, p3o ecu, I know i'm retarded (B16EG)
p28 does not have a knock sensor.
Your car will not blow up, you might, but not the car...
From what I recall the p30 is a GSR ecu which has duel butterfly, which a B16A does not, is this correct, how were you running a p30 ecu then?
Old Jun 25, 2003 | 08:52 AM
B16EJ's Avatar
the p30 is a del sol b16 ecu, I can't imagine why the chip wouldn't work, but If someone knows for sure then I would really like to know.
eg6ajk's Avatar
if you don't rev the **** out of the motor then you should be fine. Actual P28 JUN chip is acutally a P30 chip, with disabled knock sensor.
P30 ECU = 92-5 Civic SiR/Del Sol VTEC
Old Jun 25, 2003 | 08:58 AM
976's Avatar
976
New User
Default Re: p28 chip, p3o ecu, I know i'm retarded (eg6ajk)
So why do you have two topics.
This is what eg6ajk post to your last topic asking the same question:
as far as ecu hardware/anatomy goes if you comapre the UDM P28 to USDM P30 (OBDI)...the differnce lies only in the lack of knock sensor board on the P28 (jumpers to activate it). software wise of course different maps for differnet motors.
for a P30 program to work in a p28, all you need to have is disabled knock sensor code on the program. p28 is compatiable with many different ECU programs (longest the knock sensor code is disabled), these include:
P72/P30/P08/P91/P75/PR4/P61/PR3-J01/P30-G and few others.
Old Jun 26, 2003 | 08:58 AM
B16EJ's Avatar
I spoke with the guy who I bought this chip from, and he told me the p28 JUN spec chip will not work on my p30 ecu. He would have to pay to mail the chip out again and that would take an effort to do it, so I think that this chip will not be useable...
Vladglad
Jun 13, 2017 03:29 PM
B16aSir2
Feb 20, 2006 04:29 AM
systemoverload
Dec 11, 2005 10:09 AM
EFin' Kyle
Aug 2, 2004 12:30 PM
B16EJ
Jun 25, 2003 08:04 AM
