Ecu Chipping
Old Feb 19, 2006 | 05:01 AM
B16aSir2's Avatar
Default Ecu Chipping
Is it possible to take a prog designed for a p28 ecu(program chip) and install it in a p30 ecu with the same results?
Old Feb 19, 2006 | 07:23 AM
THC07's Avatar
Default Re: Ecu Chipping (B16aSir2)
I dont think so.
Old Feb 19, 2006 | 09:13 AM
mtber's Avatar
Yes, you can interchange a program which you have in a p30 into a p28 etc.
As long as knock is disabled etc.
Old Feb 19, 2006 | 06:39 PM
boosted k20's Avatar
Default Re: Ecu Chipping (mtber)
if the chip does not have barometric pressure sensor disabled then u will have problems with the chip in the P30 ecu
Old Feb 20, 2006 | 04:29 AM
B16aSir2's Avatar
Default Re: Ecu Chipping (boosted k20)
Well it's a performance chip designed by John Brown for a p28 ecu. Should have most emissions sensors disabled I would imagine. I only want to know if I can use it on my existing p30 ecu.
DA_PoWeR
Engine Management and Tuning
Aug 27, 2010 05:37 AM
ryanevansoh
Jan 13, 2009 08:50 PM
Tomdata
Apr 4, 2008 02:37 PM
Slow Egg
Mar 20, 2003 09:07 PM
