Honda S2000 Honda S2000
S2k LSD dif durability?
Old Jun 25, 2003 | 08:04 AM
leechungsr's Avatar
Default S2k LSD dif durability?
Are problems with the rear differential common?
Does this happen only with abused/raced cars?
Would a reinforced differential housing from Comptech eliminate any potential problems?
TIA!
Old Jun 25, 2003 | 08:54 AM
oos2kfan
Guest
Posts: n/a
Default Re: S2k LSD dif durability? (Lee Chun)
From what I understand in this matter, the rearend is the "weakest link" of the car but you should not have any trouble with it unless you have F/I and a grabbier clutch setup. The reinforced housing wouldn't eliminate all the problems because I think the axles need strengthening as well. I could be wrong about this but check S2KI.com for more information. Just do a search for rearend upgrades or something to that effect.
Old Jun 25, 2003 | 10:43 AM
jolt-tsp's Avatar
Default Re: S2k LSD dif durability? (oos2kfan)
Thats my understanding too. I haven't heard anyone complain about the rear on an unmodded engine. Also, if you have the stock clutch it should give before the rear diff does.
simplex
Transmission & Drivetrain
Jan 3, 2018 05:45 PM
stmotorsports
Feb 15, 2010 10:08 PM
Chiller
Feb 20, 2006 02:05 AM
driftingkitty
Honda S2000
Jan 29, 2004 11:08 AM
revhrdls
Aug 29, 2001 06:27 PM
