Honda S2000 Honda S2000
stock LSD problem
Old Jan 27, 2004 | 12:52 PM
driftingkitty's Avatar
Default stock LSD problem
ok, anyone heard that the stock LSD tend to break if you do some hard launch?
Old Jan 27, 2004 | 02:19 PM
Heath's Avatar
Default Re: stock LSD problem (driftingkitty)
I just toasted mine a few days ago. You could upgrade to the 4.77 gearset with a comptech reinforced diff. housing, or purchase a used factory unit. I know where you can get ahold of the whole rear end out of a used S2K for around $700. If your're interested in that, PM me. Hope this helps.
You can get the gearset from http://www.ricks2k.com and the reinforced diff. housing from Comptech.
Old Jan 27, 2004 | 11:38 PM
evil vapor's Avatar
sidestep the clutch at 6k+ rpm or improperly launch without loading the powertrain or quickshift lacking in skill and you'll damage the powertrain, differential assembly included. The LSD on the car doesn't break, it's the pinion gear.
Old Jan 29, 2004 | 07:23 AM
Default Re: stock LSD problem (vapor)
in that case, even if upgrading to a Cusco one won't help?
Old Jan 29, 2004 | 11:08 AM
evil vapor's Avatar
the actual limited slip unit, whether it be a torsion unit or clutch pack is not the weak part. It's the case and mounts.
Chiller
Feb 20, 2006 02:05 AM
lastpunkinline
Jan 21, 2006 09:26 PM
^AnDre^
Oct 19, 2005 08:32 PM
KFBhonda
Mar 4, 2005 02:48 PM
JDM_JON
Jan 7, 2003 11:20 AM
