Do I need to run a FPR with the FMU with JRSC?
Do i need to run a FPR with the FMU that JR includes with their SC packages? I will be running the hondata s100 w/boost. Thanks,
-Pfieff
-Pfieff
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mpir3 »</TD></TR><TR><TD CLASS="quote">you'll be fine just running the hondata
No need for the FMU w/ Hondata but keep the FPR, Might want to use it if you boost upgrade and don't have $$$ for bigger injectors right away.
Or sell it and save for bigger injectors later.
.02
.02
I don't have an aftermarket FPR, I was wondering if i should get one? The set up will be JRSC @8psi, hondata s100 w/boost, and 440cc injectors. So there is no need for the FMU or an FPR? Thanks,
-Pfieff
-Pfieff
If you install the Hondata with a base map at the same time as the JRSC, then yes, you will be fine. This: http://www.hondata.com/jrscinstall.html should give you some info on exactly what youre doing. The JR instructions will tell you to wire the relay and FMU...just skip them.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pfieffdog »</TD></TR><TR><TD CLASS="quote">I don't have an aftermarket FPR, I was wondering if i should get one? The set up will be JRSC @8psi, hondata s100 w/boost, and 440cc injectors. So there is no need for the FMU or an FPR? Thanks,
-Pfieff</TD></TR></TABLE>
Should have told us this in the beginning.
No need for FMU, S100b takes care of fuel.
