rad fan question
Old Jun 24, 2003 | 09:49 PM
metal-x's Avatar
Default rad fan question
kinda of a dumb question but if your fans dont come on at all your car will definately overheat right? does turning the heat to ON make the fans come on?
Old Jun 24, 2003 | 10:31 PM
Behan's Avatar
Default Re: rad fan question (metal-x)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by metal-x &raquo;</TD></TR><TR><TD CLASS="quote">kinda of a dumb question but if your fans dont come on at all your car will definately overheat right? </TD></TR></TABLE>
your car will overheat at idle, but if you are driving and have airflow through the radiator it will just run hot.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by metal-x &raquo;</TD></TR><TR><TD CLASS="quote">does turning the heat to ON make the fans come on?
no turning the heat on should not make the fans come on, however turning the a/c on will.
Old Jun 25, 2003 | 04:16 AM
metal-x's Avatar
Default Re: rad fan question (93preludevtec)
my car does not overheat at idle so I guess the fans are working? but it does if I don't turn the heat ON I replaced the thermostat yesterday but it still overheats
also the hose going into the thermostat does not heat up
what else could it be causing it to overheat?
HA0LEFIED
Honda Civic (2006 - 2015)
May 9, 2007 07:53 PM
PuiPui
Aug 28, 2006 05:13 PM
NA JDM GSR
May 2, 2006 03:13 PM
akad3mikz
Mar 22, 2005 01:37 AM
Be3LiCiOuS
Jul 17, 2003 05:25 AM
