OBD-II to OBD-1
Old Jun 24, 2003 | 09:37 PM
Bspec18's Avatar
Default OBD-II to OBD-1
ok i know alot of people might not wanna answer this but, im askin a serious question. I have an automatic Teg and i want to go hondata, but if i buy an OBD-II to OBD-I harness will there be a slot for the automatic harness?
I kno alot of people might turn away from the question, But im just as serious builder as anyone else on this board. TIA
Old Jun 24, 2003 | 10:13 PM
pissedoffsol's Avatar
Default Re: OBD-II to OBD-1 (Bspec18)
why man? that auto wont hold up to any seriosus power, is giong to eat half of the power you throw at it, and the gear ratios suck.
If i were you, id be looking into a manual conversion before hondata.
Old Jun 24, 2003 | 10:30 PM
Bspec18's Avatar
with all respect, have u ever riden in turbo auto LS ? its just as fast as stick (because of the turbo) and pulls just as hard, im not saying its better in anyway. but in and street light or fwy battle i've never had a problem with the shifting. only problem i have is traction at a track and im not blaming the whole problem on the tranny. im sure i'd have more potential with a manual, but sometimes u have to work with what you got, and im sure some users can respect that...
Old Jun 24, 2003 | 11:35 PM
Mr.DC2TurBo's Avatar
Default Re: (Bspec18)
I'm curious, what kind of times are u running at the tracks? With all those upgrades how much hp are u running? If you want to find a way to get some more HP, you might want to try an obd1 manual ecu. The stick ecu might allow you to stay closer to redline in each gear instead of an automatic ecu. Let me know your times and HP.
Old Jun 24, 2003 | 11:51 PM
Default Re: (Mr.JDM_KiD)
you cant run an auto tranny with a manual ecu. it just wont work.
Old Jun 25, 2003 | 07:16 AM
Default Re: (pissedoffsol)
yes it will... it has been done. What I have heard is that the d4 will flash.
Old Jun 25, 2003 | 07:52 AM
VTC_CiViC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.JDM_KiD &raquo;</TD></TR><TR><TD CLASS="quote">yes it will... it has been done. What I have heard is that the d4 will flash.</TD></TR></TABLE>
So manual tranny ECU's come programed with the shift maps for automatic trannys too?
Old Jun 25, 2003 | 06:38 PM
Default Re: (VTC_CiViC)
shift map is shift map. That is why I believe if you use a stick shift ecu then the shift pts would be better. Automatic ecu are program to shift early so by switching to a manual ecu, this might prevent the early shifting.
Old Jun 25, 2003 | 06:59 PM
Blown90hatcH's Avatar
This one is good. What controls the shift solenoids if the pinouts to the ecu have no wires comming from the auto trans? No it will not work.
Old Jun 25, 2003 | 07:00 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bspec18 &raquo;</TD></TR><TR><TD CLASS="quote">ok i know alot of people might not wanna answer this but, im askin a serious question. I have an automatic Teg and i want to go hondata, but if i buy an OBD-II to OBD-I harness will there be a slot for the automatic harness?
I kno alot of people might turn away from the question, But im just as serious builder as anyone else on this board. TIA </TD></TR></TABLE>
Email me if you are interested in an Auto-Auto OBD2-OBd1 conversion. I will make you one if you really want to stay Auto.
Turbo_EK@ yahoo.com
Jason
keung71182
May 25, 2012 12:38 PM
teefunk01
Mar 29, 2005 01:55 PM
Mr.DC2TurBo
Dec 18, 2004 12:08 PM
shadowdawn
Mar 31, 2003 01:22 PM
