Low beams and DRL running at the same time
Did a search and can't seem to find anything on this board. No one on team integra has responded on how to wire both the low beam headlights and DRL's to run together.
It would work by having the DRL's stay on when the main headlights are switched on (normally they switch off autmatically in that instance), but only have the DRL's run during the day, which is a legal requirement in Canada. Kind of like Angel Eyes on the newer BMW's but not a ring of light but just having them light up.
anyone out there with a HELMS manual could help with this. I am told all i need to know is which wire carries the current to the control unit not the resistor unit which "tells" the unit that the lowbeams are on so the DRL shut off.
Someone on TI told me that it was the red/white wire but I tried cutting that and my DRL wouldn't turn on after that but I just connected them back so they are running again but I guess that isn't the wire. Any help would be apprecitated, thanks in advance. If it helps I drive a 94 four door teg.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC2*Integra »</TD></TR><TR><TD CLASS="quote">what is a DRL light?</TD></TR></TABLE>
Daytime Running Lights
Also someone the other day asked for a DRL part number so search around I think SN is 4u2NV
fms1day
Jun 22, 2005 09:38 AM
Damon B.
Feb 22, 2003 10:06 PM
