Having probs taking off tranny fill plug bolt - Blocked (B16A)
Old Jun 24, 2003 | 07:18 PM
EF8_SiR's Avatar
Default Having probs taking off tranny fill plug bolt - Blocked (B16A)
Anyone else have this problem. Reading in the forums, everyone seems to have a breeze taking this plug off. But when i went under the car my access (w/ a socket wrench) is blocked by i'm not sure what. I tried a wrench but I think i'm stripping it instead of turning it.
Any insights?
Old Jun 24, 2003 | 07:29 PM
rioninja's Avatar
Default Re: Having probs taking off tranny fill plug bolt - Blocked (EF8_SiR)
Gotta use a wrench. A 6-point wrench if youve got it.
I never had any problems getting mine off, but last time i stripped the *****.
Had to remove the speedo pickup and fill the tranny there, takes 2.8l
if i remember correctly.
Old Jun 24, 2003 | 07:31 PM
1st-hybrid's Avatar
Use an 8mm t grip alan wrench. I just did mine today, works like a charm
Old Jun 24, 2003 | 07:55 PM
Ef Whore's Avatar
Default Re: Having probs taking off tranny fill plug bolt - Blocked (1st-hybrid)
Breaker bar with/without a socket works wonders on both the drain/fill plugs.....
Old Jun 24, 2003 | 08:53 PM
SiR Kid's Avatar
New User
Default Re: Having probs taking off tranny fill plug bolt - Blocked (Ef *****)
Uh, mine's an outie, not an innie. Sounds like he has the same problem. It's like a 14mm or 17mm WRENCH you need. I used that with another larger wrench for more torque, and just strained the fark out of my shoulder trying to get it to turn.
Old Jun 24, 2003 | 11:24 PM
RCautoworks's Avatar
Default Re: Having probs taking off tranny fill plug bolt - Blocked (SiR Kid)
My rear cross member gets in the way, I can't even fit a ratchet in there. So I use this bolt instead.
Old Jun 25, 2003 | 02:11 AM
Fobtions's Avatar
Default Re: Having probs taking off tranny fill plug bolt - Blocked (90blackcrx)
just fill it through the VSS hole. easy and fast way to pour the oil in. Cleaner also.
Old Jun 25, 2003 | 04:03 AM
EF8_SiR's Avatar
Is the VSS hole the one circled in the picture. But when u do it from there, won't u overfill ur tranny?
Old Jun 25, 2003 | 05:32 AM
REDBARON's Avatar
I've never had a problem taking that bolt off. Just get a 17mm closed end wrench. Just make sure it's a little long or you will have to use another wrench to increase the torque. I bought mine from Autozone for like 10 bucks. It's a nice long piece that has 17mm on one end and 19mm on the other.
Old Jun 25, 2003 | 11:35 AM
EF8_SiR's Avatar
Default Re: Having probs taking off tranny fill plug bolt - Blocked (REDBARON)
Ok I just fu*ked myself over now. Using a grip wrench I ended up stripping the bolt even more. I"m thinking about filling from the top seriously but how much tranny fluid does the S1 tranny take. I dont' wanan over fill nor do I wanna under fill?
Old Jun 25, 2003 | 11:44 AM
Blaze45's Avatar
Brrraaaap!
He just said 2.8 qrts.
Blaze
Old Jun 25, 2003 | 11:52 AM
EF8_SiR's Avatar
Default Re: Having probs taking off tranny fill plug bolt - Blocked (Blaze45)
Whoa man reading another forum there are all sorts of #'s
https://honda-tech.com/zerothread?id=471857
he said 2.8L which equals 2.96qts; that sounds like quite a bit
Old Jun 25, 2003 | 12:06 PM
shoden's Avatar
That is a lot. Not sure about the S1, but the Y1 takes 1.9L to fill. The tranny isn't supposed to be completely full... instead, you're supposed to fill it until it runs out the fill plug. If you've stripped it and have to fill from one of the bolts on the top of the case, you'll have to be careful to not put too much in.
Old Jun 26, 2003 | 04:18 PM
EF8_SiR's Avatar
Default Re: Having probs taking off tranny fill plug bolt - Blocked (shoden)
The y1 same as the jdm s1 in terms of volume?
What woudl happen if u over fill?
Old Jun 26, 2003 | 05:55 PM
90civichbsi's Avatar
ehhem, http://b16a.honda-perf.org/care.html
its 2.2 quarts, if you dont believe me check out the sir manual
http://www.hondacrx.co.uk/ section 3-6
this way there is no more argueing
BTW all the trannys have the same volume, they all use the same cast, just have different gear gatios
Modified by 90civichbsi at 3:36 AM 6/27/2003
Old Jun 26, 2003 | 08:01 PM
EF8_SiR's Avatar
Default Re: Having probs taking off tranny fill plug bolt - Blocked (90civichbsi)
Good **** !!
Old Jun 26, 2003 | 09:20 PM
b16_madman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90blackcrx &raquo;</TD></TR><TR><TD CLASS="quote"> </TD></TR></TABLE>
which transmission do you have, b/c my J1 (i think...) it has a tube on the top where i can pull off a plug and pour in from there. I'm not sure, but I think so. I probably need to do this also.
Old Jun 26, 2003 | 10:00 PM
Default Re: Having probs taking off tranny fill plug bolt - Blocked (B16_madman)
Thats an s1, are you talking about the power steering fluid tubes, thats located a little higher in that pic.
diewX3
Mar 18, 2005 04:18 PM
Mackenzie
12
Oct 30, 2004 07:49 PM
LOWNSLOW
Apr 11, 2004 11:47 AM
Art Vandeleigh
20
Nov 16, 2002 08:23 PM
lmscagain
May 13, 2002 08:29 AM
