fields Vtec controller harness
Old Jun 24, 2003 | 05:55 PM
RiceNmotioN's Avatar
Default fields Vtec controller harness
i brought a Fields vtec from a friend... it came with out the harness to the unit it self.... one guy i talk to said you can make your own harness to the unit... will it work if i make my own harness for the unit... b/c Fields stop making there products....
Old Jul 22, 2003 | 03:48 PM
greebler's Avatar
Default Re: fields Vtec controller harness (RiceNmotioN)
bump cuz i am in the same situation
Old Jul 22, 2003 | 03:49 PM
greebler's Avatar
bump
Old Jul 23, 2003 | 06:42 AM
Xsi's Avatar
Xsi
If you are handy with a soldering iron you can solder the wires straight onto the pins at the back of the unit.
Undo the screws and open it up, theres a white plastic bit that gets in the way of the pins so I used my soldering iron to melt this bit off.
When looking at it from the back you will see 16 pins like this:
1 2 3 4 5 6 7 8
9 10 11 12 13 14 15 16
The numbers correspond to these coloured wires :
1) Red
2) Pink
3) Purple
4) White/Red
5) Brown
6) Orange
7) Blue
8) Black
9) White/Blue
10) Green
11) Light Blue
12) Grey
13) White
14) White/ Green
15) Yellow
16) White/ Black
I don't accept any responsibility if you screw it up but I have had mine working fine like this for over a year now
Old Jul 23, 2003 | 12:16 PM
greebler's Avatar
Default Re: (Xsi)
so u soldered directly onto teh ecu plug?
thanks for the info.
Old Jul 23, 2003 | 04:31 PM
Xsi's Avatar
Xsi
Yep, straight onto the pins in the back of the unit
marks97el
Sep 15, 2008 05:17 PM
djxtc65
May 27, 2006 03:32 PM
JCracer723
Dec 4, 2003 04:30 PM
sanders711
Oct 12, 2002 10:28 PM
