H22 guys with H23 tensioners! Where did you get one?
Old Jun 24, 2003 | 05:16 PM
poison's Avatar
Default H22 guys with H23 tensioners! Where did you get one?
Those of you guys running H23 manual tensioners or purchased a new one, did you guys get 'em from the Honda dealership? I'm on the verge of getting on and about to go to the Honda dealership since Hondaautomotiveparts.com looks as though they have auto tensioners on the diagrams
How much was it and where did you get one? I'm not a cheap ***, but I don't want to be spending ~$200 for a damn tensioner either =X
TIA.
Old Jun 24, 2003 | 07:14 PM
Boostless97Lude
Guest
Posts: n/a
Default Re: H22 guys with H23 tensioners! Where did you get one? (poison)
i bought all the tensioner parts for 4th gen Si from Honda
Old Jun 24, 2003 | 07:15 PM
ichibanjap's Avatar
I got mine from Honda
Old Jun 24, 2003 | 07:22 PM
fizzbob7's Avatar
Default Re: H22 guys with H23 tensioners! Where did you get one? (ichibanjap)
honda has a back order on one of the parts needed to convert it, when i checked a couple months ago....i think it was the plate.......but anyway....honda if you can
Old Jun 24, 2003 | 08:04 PM
poison's Avatar
Default Re: H22 guys with H23 tensioners! Where did you get one? (fizzbob7)
Ok, works.
Hopefully they are not on back order when I pay 'em a visit.
Old Jun 24, 2003 | 10:38 PM
satan_srv's Avatar
Got them off a dude that wrecked his motor.
Old Jun 25, 2003 | 04:18 AM
Mover's Avatar
I took a closer look at the H23 tensioner I put on my H22 while taking another part of the motor out. The timing belt doesn't sit perfectly on top of the timing belt tensioner pulley with the H23 conversion. If you look at it, the outer perimeter of the pulley closest to the block is exposed (1/8 - 1/4 inch) and not covered by the the timing belt. The tbelt and bal shaft belt which are close with the stock H22 tensioner assembly, are extremely close now.
Modified by Mover at 8:32 AM 6/25/2003
Old Jun 25, 2003 | 04:28 AM
satan_srv's Avatar
Default Re: H22 guys with H23 tensioners! Where did you get one? (Mover)
That's because you missed the 11mm washer thatspaces the tensioner pulley out further.
Old Jun 25, 2003 | 04:32 AM
Mover's Avatar
Default Re: H22 guys with H23 tensioners! Where did you get one? (satan_srv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by satan_srv &raquo;</TD></TR><TR><TD CLASS="quote">That's because you missed the 11mm washer thatspaces the tensioner pulley out further.</TD></TR></TABLE>
No..I got the 11mm washer in there.... part #30
http://www.hondaautomotivepart...82%29
Modified by Mover at 8:49 AM 6/25/2003
Old Jun 25, 2003 | 08:52 AM
2point6's Avatar
OK, the balance shaft pulley (tensioner) is from which engine? It must be from the H23. If you are using the H22 balance shaft pulley, you must add a washer between the timing belt pulley and the balance shaft pulley. this allows for more clearance. if you don't add a space between the pulleys, it will eat the timing belt up.
I will try to do a detailed write up on this (with pictures) tonight since it is a hot topic. I will post it here as well, but it will be up on my site first. http://www.collectiveracing.net It will be in the how to's section.
Old Jun 25, 2003 | 10:07 AM
Mover's Avatar
Default Re: H22 guys with H23 tensioners! Where did you get one? (2point6)
They're all H23 parts. I'll PM you
Old Jun 25, 2003 | 09:33 PM
ichibanjap's Avatar
What's up with your site, it just kept loading forever. I need to know how we figure this one out.
Old Jun 26, 2003 | 12:20 AM
poison's Avatar
Ya i hear that. I'm definitely interested on seeing the H23 tensioner write up.
Old Jun 26, 2003 | 07:01 AM
DLB1994's Avatar
i may have one if you need it
Old Jun 26, 2003 | 07:29 AM
2point6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ichibanjap &raquo;</TD></TR><TR><TD CLASS="quote">What's up with your site, it just kept loading forever. I need to know how we figure this one out.</TD></TR></TABLE>
I just found this as a problem... It is being worked on. I haven't finished the write up yet. But it will be up soon. here is a link to get around the intro page:
http://www.collectiveracing.ne...b787b
there is a new intro page to take you to the board
Sorry for the inconvienience. BTW, I am trying to get as much detail into the changeover so it is taking a little longer than planned, sorry.
Modified by 2point6 at 9:16 AM 6/26/2003
Old Jun 26, 2003 | 01:35 PM
poison's Avatar
website is sweet. can't wait to see this conversion bro.
Old Jun 26, 2003 | 01:53 PM
hatchback19's Avatar
what do you guys use the h23 tensioners for ?
thx
Old Jun 26, 2003 | 02:50 PM
poison's Avatar
Default Re: H22 guys with H23 tensioners! Where did you get one? (hatchback19)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchback19 &raquo;</TD></TR><TR><TD CLASS="quote">what do you guys use the h23 tensioners for ?
thx</TD></TR></TABLE>
To convert from an auto tensioner to a manual one.
Old Jun 26, 2003 | 02:53 PM
DsITR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by poison &raquo;</TD></TR><TR><TD CLASS="quote">
To convert from an auto tensioner to a manual one.</TD></TR></TABLE>
werd, reason being the auto is more likely to fail..
Brandon, I have the entire parts list w/part #'s if you need it. lemme know when you are going to do this, I need to change my timing belt.
PS, Im really goint to be pissed if It's easier the change the belt in the hatch, than my damn Lude..
Modified by dsludefosho at 4:48 PM 6/28/2003
Old Jun 27, 2003 | 10:24 AM
2point6's Avatar
Sorry guys... I am running behind on the write up. I will have it up soon.
Old Jun 27, 2003 | 11:32 AM
Mover's Avatar
Default Re: H22 guys with H23 tensioners! Where did you get one? (dsludefosho)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dsludefosho &raquo;</TD></TR><TR><TD CLASS="quote">
werd, reason being the Manual is more likely to fail..
Old Jun 28, 2003 | 02:49 PM
DsITR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mover &raquo;</TD></TR><TR><TD CLASS="quote">
DOH.....fixed, sorry for any confusion.
Old Jun 29, 2003 | 03:28 PM
poison's Avatar
Modified by dsludefosho at 4:48 PM 6/28/2003</TD></TR></TABLE>
lol I just did it. It was pretty easy, just little room to work around ;x
I'll give ya a call a little later, or hit me up AIM.
pkolaboy
Jun 27, 2008 06:47 PM
Jmoto911
Feb 28, 2007 12:21 PM
kholmes
Mar 29, 2006 03:16 AM
Yuleluder
Jan 4, 2003 01:23 PM
96SR-V
Jun 27, 2002 12:53 PM
