Will B16 header fit on B18B
I was about to buy a header(dc sports) off my friends civic si B16A and he said that it would fit my b18b but i don't really trust his judgement. Could someone please help thx
It will bolt up to the head just fine. All b-series headers use the same head flange pattern.
You may have to cut or lengthen your exhaust piping though if the collector doesn't end in the same location as your stock header.
I have a 00' Si DC header on my 99' LS and everything is ok length wise I had to take it to a muffler shop and have them cut off the flange, turn it and weld it back on because like someone else said, the flanges won't line up.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FrostyDC4 »</TD></TR><TR><TD CLASS="quote">It will bolt to the head but it wont clear the block.</TD></TR></TABLE>
It will still clear the block. It just wont bolt up to the cat thats all without modification.
ok this is for sure......It will fit and clear the block. The only thing is that the flanges on the b16 header and the flanges on the ls cat wont line up. You will have to get it welded or something
