5 inch monster tach help
Old Jun 24, 2003 | 02:54 PM
stripes777's Avatar
Default 5 inch monster tach help
anyone know my my 5 incher autometer tach is off by 700, it shows up as 700 more. ive tried everything. made sure the connection to the wire on the distributor was good, even tried new grounds and power sources, same thing.
once in a long while, it'll jump to normal reading, like once a month, but then it would only stay there for like 2 minutes , haha ghetto
any help would be great! thanks
Old Jun 24, 2003 | 02:57 PM
blackhatchy's Avatar
Default Re: 5 inch monster tach help (stripes777)
just leave it and do the math.
Old Jun 24, 2003 | 03:06 PM
stripes777's Avatar
been doing the math, for like 2 years, haha , just want something that works! lol
Old Jun 24, 2003 | 03:08 PM
jdmsiR20's Avatar
Default Re: (stripes777)
yup... i have the same problem... mine is off by like 200 or something, not to huge, but i think i'd rather just sell it any takers? $40.. haha!
Old Jun 24, 2003 | 03:10 PM
rodrez.'s Avatar
Are you comparing it to a stock tach? The stock one is usually inaccurate.
Old Jun 24, 2003 | 03:12 PM
jdmsiR20's Avatar
Default Re: 5 inch monster tach help (rodrez)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rodrez &raquo;</TD></TR><TR><TD CLASS="quote">Are you comparing it to a stock tach? The stock one is usually inaccurate. </TD></TR></TABLE>
if thats for me, then no, because i took it to fuel cut a couple times, , and from what the tach displays, its off...
Old Jun 25, 2003 | 01:07 AM
stripes777's Avatar
40 bucks for a monster tach with a light? if so , thats a hot deal man, ill buy another one and put in my dads camry, haha.
its off, i can tell from idle and vtec engagement. sometimes it goes to accurate, but only stays there for a while
its almost like it has 2 modes, perfect, and added 700, lol
Old Jun 25, 2003 | 04:33 AM
sohc_boy's Avatar
do u have the tach set for a 4 cylinder?
Old Jun 25, 2003 | 12:02 PM
stripes777's Avatar
im pretty sure, when i first got the car, it was perfect, now its a bit off
btw, the green wire is connected, the rest are cut off
Old Jun 25, 2003 | 12:05 PM
Nextelbuddy's Avatar
on the back of the tach there are little loop wires that each pertain to what cylinder car u have . for 4 cylinders u need to cut all of them , meaning no wire on the back should be together. all shodl be cut.
Old Jun 25, 2003 | 12:23 PM
Jonathan_ED3's Avatar
Default Re: (nextelbuddy)
my 5" autometer tach is deadly accurate...I'll never get rid of it.
Old Jun 25, 2003 | 01:01 PM
trix004's Avatar
anyone wanna sell me a 5" autometer tach? pm a price
-Trinitron-'s Avatar
get an AFC...it will show you what rpm the ecu sees. Then you can tell which is really wrong and how much.
Old Jun 25, 2003 | 01:22 PM
stripes777's Avatar
anyone know if i can jus tap the green wire to a wire on the ecu, instead of going to the distributor? if so, which wire is it?
Old Jun 25, 2003 | 01:26 PM
yep. you can.
it's a light blue wire in the back of the cluster.
this wire runs right to the distributor, so there's no need to go all the way there.
that's where i've got mine tapped in at, and like i said...deadly accurate
Old Jun 25, 2003 | 01:27 PM
Default Re: (hot_EH)
oh i thought you said 'cluster'. haha 'ecu' man i'm dumb.
should be the same color ont he ecu though.
Old Jun 25, 2003 | 01:29 PM
ATS*Mark's Avatar
OG triple OG
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hot_EH &raquo;</TD></TR><TR><TD CLASS="quote">my 5" autometer tach is deadly accurate...I'll never get rid of it.
aahh deadly accurate .....mine is too.
you guys that ar having problems could have bad internal coils
Old Jun 25, 2003 | 02:14 PM
CStyles45's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nextelbuddy &raquo;</TD></TR><TR><TD CLASS="quote">on the back of the tach there are little loop wires that each pertain to what cylinder car u have . for 4 cylinders u need to cut all of them , meaning no wire on the back should be together. all shodl be cut.</TD></TR></TABLE>
Yep, that's how my autometer is set up. Cut them all and you should be good.
Old Jun 25, 2003 | 04:42 PM
stripes777's Avatar
ya theyre are all cut, except for the 4 needed wires( ground , power source, lighting and ****, and the green to the wire. wuts an internal coil? is that something thats cheap and can be easily changed?
i jus changed my cap and rotor for the dist. but the prob was there way before i did it
JuggerNuts
Jun 18, 2006 07:35 PM
Beezle
Nov 2, 2004 10:33 AM
Beezle
Aug 3, 2004 05:49 AM
vteczone
Dec 18, 2003 08:13 PM
90da
Jan 21, 2003 03:44 PM
