Anyone Ever has this problem
Old Jun 24, 2003 | 01:12 PM
Iceycrx's Avatar
Default Anyone Ever has this problem
Have a d16z6 using the stock obd0 setup, all sudden it started throwing a code 10 after the swap. so I changed out the sensor, still have the problem. It throws out other codes that seem to come and go. I looked into the chiltons and it suggested that either its the sensor, or the ecu, any idea why either would go bad after working fine before swapping the motors?. Also changed the power cable to a larger one, not sure if that would cause any problems.
thanks
Old Jun 24, 2003 | 01:36 PM
squad801's Avatar
Default Re: Anyone Ever has this problem (Iceycrx)
I pretty sure if ti were the ecu it would either flash one or just stay solid. have you checked the main relay ?
E M Wynne
Jul 13, 2017 09:26 AM
KidRuthless
Jun 5, 2014 09:11 PM
jdm inc
Engine Management and Tuning
Jun 16, 2012 10:41 PM
Hond@
Dec 22, 2010 08:20 PM
rainman
Jan 9, 2003 12:58 PM
