Polishing Max Rev manifold.
Old Jun 24, 2003 | 10:06 AM
PM-Performance's Avatar
Default Polishing Max Rev manifold.
Any downsides of polishing the manifold .it looks like **** after some use, but i heard to watch for rust when messing with the finish? doe sit really need the high lsuter finish or just a decent sanding ? anyone have a list of steps to polish this thing
Old Jun 24, 2003 | 11:39 AM
Default Re: Polishing Max Rev manifold. (itr206)
no body? i did a search and came up with nada , unless i aint searching right.
Old Jun 24, 2003 | 11:46 AM
redlinegsr's Avatar
if you do get ready to use some elbow grease and about 8 hours of your time
Old Jun 24, 2003 | 11:50 AM
Farnsrocket's Avatar
Default Re: Polishing Max Rev manifold. (redlinegsr)
Hey man! I did mine......it's worth it........starts out silver when you are done, then turns gold and purple when it gets hot. I will get some pics and a list of sandpaper later on tonight.
Old Jun 24, 2003 | 11:53 AM
CzanSOHC's Avatar
Default Re: Polishing Max Rev manifold. (Farnsrocket)
i painted mine...but sanding is cool too.
The only part that rusts are the flanges after time...they are not SS...the rest of the mani is though.
Old Jun 24, 2003 | 11:56 AM
Default Re: Polishing Max Rev manifold. (CzanSOHC)
Cool thanks farnsocket. i just hate the way it looks , it kills the whole look of the under the hood of the car. now the motors out so i got time to put into it to get it lokoing good .
Yea when you get a chance to list some steps to do it right , id appreciate it .
thanks.
Old Jun 25, 2003 | 04:41 AM
bump
Old Jun 25, 2003 | 05:08 AM
Here's after I polished it:
Here's the best "after" pic of it that I had on hand:
Modified by Farnsrocket at 6:37 AM 6/25/2003
Old Jun 25, 2003 | 05:15 AM
B18c1turboedEK's Avatar
what sand paper did u use to do it?? looks good!!!!!
Old Jun 25, 2003 | 05:18 AM
swlabhot's Avatar
Care to polish my for the of HT
Old Jun 25, 2003 | 05:39 AM
Default Re: Polishing Max Rev manifold. (swlabhot)
Thanks! Basically I started out with a course emery paper, maybe like 100 grit. You just don't want to make scratches in the mani that will not come out with the finer paper. I then worked up to 200, 300, 400 and then 600.......I actually had some 1000 grit stuff that I finished off with. You can do a small spot underneath the mani real quick with all the paper you have to see what it will look like before you do the whole mani. Lastly, I used Mothers Mag/metal polish. I tried using my Dremel with a sandpaper bit, but it seemed to burn areas and was not as consistent as doing it by hand. It definately looks badass once it turns gold and purple.......it gives it a shiny finish, almost like it is clear coated, instead of the dull rough look. Hope this helps.
Old Jun 25, 2003 | 06:11 AM
sweet thanks for the info , that looks alot better
Old Jun 25, 2003 | 07:21 AM
93LSivic's Avatar
Hey Pete, when I told you about the "rusting" I remembered that it started after I spent 2 weeks at the beach. I guess the salt in the air got to it or something.
Anyways, dont make it look chrome like mine here---im sure it wont have the "rusting" issue if you keep it a little less polished and it'll still look nice.
Old Jun 25, 2003 | 07:30 AM
Default Re: Polishing Max Rev manifold. (93LSivic)
damn that **** is Bling Dan , you laid it down on th epimp sheepskin rug to take the pic? looks like you skinned a Yetty lol .
how you think it'll turn out with the bead blast>?
Old Jun 25, 2003 | 07:35 AM
DC2R714's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr206 &raquo;</TD></TR><TR><TD CLASS="quote"> looks like you skinned a Yetty lol.</TD></TR></TABLE>
Haha bringing back your Expo experiences again Pete! haha
Old Jun 25, 2003 | 07:36 AM
93LSivic's Avatar
I think i remember Goeff from Full Race posting pics of his manifolds a while back where he had different cosmetic looks. One being glassbead, one polished, one natural...etc. He uses the same grade stainless as the maxrev so you will get a good idea.
Maybe he can chime in here and help out.
Old Jun 25, 2003 | 07:54 AM
if mine looked like yours, i could deal with that , i like the look of your manifold. ill bring it up and let you try it, it should only take a few min with a blaster.
Old Jun 25, 2003 | 10:26 AM
Can u get a drag manifold to look like that as well???
Old Jun 25, 2003 | 10:44 AM
Default Re: Polishing Max Rev manifold. (Koticcivic4u)
no
1999siguy
May 25, 2009 03:54 PM
SuperSi
Jun 3, 2006 03:20 PM
Adi Radoncic
Aug 25, 2003 10:05 AM
ludelvr
Dec 24, 2002 01:37 PM
simike
Jul 20, 2002 09:32 AM
