Can you get too cold of a spark plug?
Is it possible to get too cold of a plug? I'm turboing my Prelude and was shopping for plugs adn came up with this stupid quesion. So, is is poddible? And what would happen?
wow from what i learned at the tuning seminar by ben strader yes you can actually get a too cold plug what happens is that it does burn correctly on the electrode strap. what you want is actually a colored rainbow color, on the strap too cold or too hot and too much retard and too much ignition advance will cause that rainbow color to move up and down.
I'm using Apexi racing plugs #8...they are actually better than the NGK's I had. Unfortunately they cost $12 EACH
#7'spictured here
#7'spictured here
heres my suggestions.. buy regular plugs for the street use and another set of sparkplugs for the track.. i suggest iridium for the track.. and 1 step colder for the street.. i mean the iridium plugs should last for a long time since its gonna be used only so often just down the track and back...after that just swap it out.. doest take long anyways just keep a wratchet and extention and socket for the plugs and your all set...
i'm still running stock plugs/heat range. don't seem to have any probs at 8psi running 1/3 degree of retard per pound of boost. does this sound right?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo E »</TD></TR><TR><TD CLASS="quote">sorry to hijack, but i'm running Bkr7E specs below. my plugs seem to foul rather quickly. should i use standard plugs?</TD></TR></TABLE>
BTW which is colder BKR7E (shorter/recessed insulator) or 7FR5J-11 (longer/extended insulator)
From: 99th level of hell, where all roads only go straight, where curves go to die. Houston Texas
On my 99 Civic Si, the BKR7E copper plugs were 1 step colder than stock. But I'm using some BKR7EIX-11's Iridiums which are 2 steps colder, which is way too expensive, and an overkill, so I'll be going to BKR7E.
Besides, I'm only pushing 5psi.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MiraiZ »</TD></TR><TR><TD CLASS="quote">I'm using Apexi racing plugs #8...they are actually better than the NGK's I had. Unfortunately they cost $12 EACH
#7'spictured here</TD></TR></TABLE>
Not to say they aren't good, but I'd wager they are made by NGK/Denso. I don't think there is any way that Apexi manufactures plugs.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EE_Chris »</TD></TR><TR><TD CLASS="quote">Article on Plugs
Might be of some interest to the current topic.</TD></TR></TABLE>
good stuff
thanks
good stuff
thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ion_four »</TD></TR><TR><TD CLASS="quote">
Not to say they aren't good, but I'd wager they are made by NGK/Denso. I don't think there is any way that Apexi manufactures plugs.</TD></TR></TABLE>
you're probably right...they look suspiciously like NGK...I guess its just the lower heat range that makes my car run smoother...
Casey
Mar 19, 2002 07:00 PM
