PITA spark plug boots
Just wanted to share my experience with a small, but troublesome problem.
While doing some minor tune up stuff, I was replacing my spark plugs. At the end of the wires there's this little boot thingy that likes to remain on the plug and not come out with the wire.
I've successfully handled this with a coat hanger in the past, but I found that this isn't the best way to deal with the problem. Using the coat hanger I managed to rip the plug wire boot.
So the next day (it was 10 pm) I made a trip to NAPA and bought a 12 dollar pair of long-*** needle nose pliers. Ahhh, much better now. It's so much easier to work on stuff when you have the right tool.
Ciao dudes.
Ciao dudes.
From: Where the hell is Bullhead City, Arizona, U.S.A. Formerly of Huntington Beach, Ca 92649
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by emwavey »</TD></TR><TR><TD CLASS="quote">At the end of the wires there's this little boot thingy that likes to remain on the plug and not come out with the wire.
I just use a little bit of "vaseline" on the head of the plug and inside the boot. Slides off much easier that way.
Just my .02 $
Just my .02 $
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. B in Az »</TD></TR><TR><TD CLASS="quote">
Just my .02 $</TD></TR></TABLE>
I use Dielectric grease but same difference.
dude.. i've never had that problem.. whether it be with di-electric grease or not..
but anyway, what kind of wires? i use NGK blue's..
I think what he is actually talking about is the rubber boot inside the spark plug socket and it gets stuck on the spark plug when you tighten it and try and pull it out.
If hes talking about the actual boot that goes on the wires connection to the distributor then I say get some less crappy wires, my NGKs have those boots like hot glued in place or something.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FourthGenHatch »</TD></TR><TR><TD CLASS="quote">I think what he is actually talking about is the rubber boot inside the spark plug socket. </TD></TR></TABLE>
Yeah I've had that happen too, but that's an easier fix.
What I'm talking about is at the end of the spark plug wire there is typically a little insulator boot. Kind of looks like a tootsie roll. Depending on what kind of wires you use that boot can decide it likes to hang out on the spark plug rather then come out with the wire. If you haven't had this happen, consider yourself fortunate.
Because I was going to a track day the following morning, I had to buy some cheapos to replace the wires... they weren't cheap. I figured I could just tranfer a new boot from the crappy wires, but on the new wires the boots seemed like they were pretty well afixed, so the crappy new wires are on the car now.
Sheesh, that's confusing just to write, I hope you can follow that.
Are most of you guys using factory wires?
nonvtec92
May 13, 2008 01:39 PM
