ABS-Checkbox
Old Jun 24, 2003 | 02:10 AM
Daniel26's Avatar
Default ABS-Checkbox
I don't know if this is right here...Mods: please move it if not.
I have some trouble with my ABS. I have the Workshopmanual. There is (for the workshops) an Tool called ABS-Checkbox. Has anybody a wiring-diagramm of this Box? I will build it for me.
Thanks
Old Jun 24, 2003 | 06:21 AM
Daniel26's Avatar
Default Re: ABS-Checkbox (Daniel26)
Nobody? Come on guys, i nedd it urgently
Old Jun 24, 2003 | 08:25 AM
JimBlake's Avatar
Maybe you mean a break-out box??
That connects in the wiring harness between some existing plug. You unplug the harness, put this in-between, and plug it back in. Now all the proper connections are maintained, but you can check each wire with a meter WHILE it is still connected.
Old Jun 24, 2003 | 09:17 AM
Daniel26's Avatar
Default Re: ABS-Checkbox (JimBlake)
No, this would be easy to build. I mean that Box that you connect to the ABS-Wiring-harness under your right seat. With this Box you can Check your ABS-System and switch between the sensors on each wheel.
I try to Post a Picture of it. There is a Pic in the Workshop-manual.
Old Jun 24, 2003 | 11:15 PM
Daniel26's Avatar
Nobody Knows?
Old Jun 25, 2003 | 03:47 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Daniel26 &raquo;</TD></TR><TR><TD CLASS="quote">Nobody Knows?</TD></TR></TABLE>
Probably not... (just kidding)
I'm not sure, but that tester box looks like it can simulate the signals coming from the wheel sensors. That way you can test the ABS controller without driving the car.
So it's like a breakout box, but with oscillator(s) that can be switched into different circuits. But I don't know what those signals are supposed to look like. If you wanted to design one for yourself, first you need a breakout box like I described. Then use an oscilloscope while driving to see what the signals are supposed to look like. Then make or buy an oscillator to simulate that signal, and hook it into that box so you can switch it into the wheelsensor circuits.
medjosh6
Apr 12, 2013 03:26 PM
team_lunatics
Aug 9, 2011 12:06 PM
vinced87ek
Apr 8, 2010 06:47 AM
RobbieG35
May 28, 2006 08:12 PM
