smoke from tail pipe?
Old Jun 23, 2003 | 07:29 PM
CRXracer88's Avatar
Default smoke from tail pipe?
ok my problem is when you floor it in first i get a big puff of smokke that comes out i cant tell the color it either white or blue..... but it only smokes when you first get on it . you can sit there and rev it up all day and it wont smoke.... i was thinking it might be the valve seals or maybe the rings .... it a all stock d16a6 with 160k on it .. let me no what you guys think!
Old Jun 23, 2003 | 08:48 PM
I8ayellowcrayon's Avatar
Get you some of that Castrol High Mileage oil. Those commercials are hilarious. Hell I don't know whats wrong with it. If its when you first get on it, then I doubt its your rings. I'd say your dumping oil out of your seals because all that pressure when you give it some hella gas your cylinders have such a vacuum that those worn out seals just give way to oil. When oil burns its dang smelly. Hehe, and it'll leave a white/grey smoke.
Man. I'm in a good mood now; I need to download those Castrol commercials. With the blue Ford minivan ramping a little hill. Thats quality stuff right there. Anyways man, if it is the seals, you may want to run abou 1k miles with some good ol' engine honey. Only do that once though, and don't do any racing while you have it in. Just do some calm every day driving. Just my idea though, I'm not a certified mechanic....
Old Jun 23, 2003 | 08:49 PM
gethighonsi's Avatar
Default Re: smoke from tail pipe? (CRXracer88)
find out the color and if it has a smel then i might can help u out it can be alot of things if its only in first gear it may have a crack somewere and you are just blowing out condinsation.good luck please find out more details
Old Jun 23, 2003 | 08:50 PM
or just go to a shop, ask 'em about it, and see if you can't get them replaced while getting a multi angle valve job and porting.
Old Jun 24, 2003 | 12:44 AM
CRXracer88's Avatar
well i did notice it has hella nasty smell to it ... my friend was behind me and he said it smelled like a$$... he said the smoke looked whitesh grey ......... i was also wondering if not have the cat would cause it to smoke alittle ....... whats engine honey ? never heard off it.
Old Jun 24, 2003 | 09:22 PM
Engine honey is a little slang term me and a lot of other people (that I talk to anyways... maybe its just me...) use for Resto something or other. It fixes seal leaks and helps get better compression on old worn out engines. Resto.... Resto.... something. They have it at O'reillys and Auto Zone and all that. Just ask them for something that will 'hopefully' fix your problem. The one I'm thinking of is in a Silver cylinder can thing. If you don't have a cat, then your car will spit out black exhaust when you're heavy on the gas. The only thing a cat converter does is burn off unburnt (redundant....) exhaust for better emissions. So really the black exhaust is gas that hasn't been completely burned.
924doorEG
31
Jan 8, 2008 12:25 AM
tbuck23
Apr 22, 2007 08:09 PM
egdriver94
12
Aug 20, 2006 07:21 PM
Layziebtnh055
Apr 18, 2004 11:45 AM
Guitarzann
Dec 21, 2001 07:59 PM
