bleeding the clutch
It's been a while since I've done this, but I'm pretty sure that you bleed them the same way that you would bleed your brakes. I the bleeder valve is underneath the car on the passenger side of the transmittion.
I'm not a 100% about the location, but I KNOW that it is somewhere close to there.
Good Luck!
Good Luck!
the bleeder is on the slave cylinder..in front of the tranny..where the boot that covers the clucth release fork....u cant miss it..bleed it like u would the brakes..
you know what the bleeder valve looks like, cuz i looked under there and i saw nothing but bolts and one bolt the has a square in it, could it be that one?
is it possible to have a hole in the line or something because i tried to bleed my clutch with a bleeder tube like 3 times and it didnt work right just like halfway
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hakemjmba »</TD></TR><TR><TD CLASS="quote">you know what the bleeder valve looks like, cuz i looked under there and i saw nothing but bolts and one bolt the has a square in it, could it be that one?</TD></TR></TABLE>
The square is either your fill or drain plug for the tranny.
The bleeder is the nipple on the end.
wow u guys thanks a lot, hopefully this fixes my clutch. my clutch is really soff and seems like there is no pressure to it, hopefully this fixes it! thanks!
riceburnah
Jun 2, 2003 04:23 AM
