S-AFC Ground wires....which one goes where???
Old Jun 23, 2003 | 04:36 PM
sivik2nr's Avatar
Default S-AFC Ground wires....which one goes where???
I can't figure out from the manual where the two ground wires go, on a S-AFC.
Red wire = power
Green = RPM
Gray = Throttle Signal
Black = Ground
Brown = Ground
The manual tells you what the Red, Green , and Gray go to and where one ground goes to, but it doesn't say which color it is, and where the 2nd ground goes.
I also understand that you are supposed to put the black closer to the ecu...does it matter how much closer?
Old Jun 23, 2003 | 05:56 PM
Yosshaa's Avatar
i just read in the safc manuel that the brown wire has to be close then the black wire... theyboth clamp into the ground wire to your ecu which is in different places depending on what ecu you have.
Old Jun 23, 2003 | 09:12 PM
sivik2nr's Avatar
Default Re: (ambition)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ambition &raquo;</TD></TR><TR><TD CLASS="quote">i just read in the safc manuel that the brown wire has to be close then the black wire... theyboth clamp into the ground wire to your ecu which is in different places depending on what ecu you have.</TD></TR></TABLE>
ok yeah, I just re-read everything... and see what to do .... thanks...
eg6madness
Nov 17, 2007 04:46 PM
EK k kay
Jul 8, 2006 08:25 PM
red1997civic
Dec 25, 2003 12:50 PM
DsMWookie
Jan 31, 2003 08:31 AM
T25 civic
Oct 6, 2002 02:11 PM
