93 civic EX gauge cluster
Old Jun 22, 2003 | 09:37 PM
civicsleeper93's Avatar
Default 93 civic EX gauge cluster
anyone walk me through taking out dx cluster? i know theres a bolt under the hazard and 2 on the top dash but why is it hard to get it out? Vents?
Also... when swapping a b16a2 motor u just plug all harness in and you will be left with one harness being extra unpluged? and you just rip old stock axles off and put new b16a2 axles on? and it isnt necessary to wire a vtec wire is there?
Old Jun 22, 2003 | 09:54 PM
Cheivic's Avatar
Default Re: 93 civic EX gauge cluster (civicsleeper93)
Ok. After you remove the two bolts from the top of the cluster you just pull it out. There's little clips that hook on to the bottom of the bevel so be careful getting the bottom part out. Just rip it out after that. Take out the hazard lights first. And unplug the clock before you take out the bevel.
Old Jun 22, 2003 | 10:04 PM
DOHCtorTHRUST's Avatar
Default Re: 93 civic EX gauge cluster (Cheivic)
dont forget about unscrewing that screw after you pull off the hazards...
i broke two casings because of that...
Old Jun 22, 2003 | 10:12 PM
Eyes Only's Avatar
Default Re: 93 civic EX gauge cluster (DOHCtorTHRUST)
pull it out slowly
slammedem2
Mar 12, 2011 12:00 PM
JDMb18c1HATCH
Mar 9, 2011 08:01 PM
pnltnc
Apr 4, 2004 10:04 AM
93jdmhatch
Feb 13, 2004 03:52 PM
80884
Sep 17, 2003 05:53 PM
