how do you do a compression test?
Old Jun 21, 2003 | 11:07 PM
B_1_8_hatch's Avatar
Default how do you do a compression test?
my friend wants to do one on his motor, but he's never done it before. is it hard to do? any tips will help.
thanks
Old Jun 21, 2003 | 11:53 PM
blah13's Avatar
Default Re: how do you do a compression test? (93hb)
Searching for "compression test" in archived returned 292 topics...please use search first.
Old Jun 22, 2003 | 01:30 AM
John O's Avatar
Default Re: how do you do a compression test? (blah13)
http://www.c-speedracing.com/h...t.php
Old Jun 22, 2003 | 01:47 AM
irev210's Avatar
warm car up, make sure its fully warmed up
remove ecu fuse
remove spark plugs
GENTLY thread compression tester into sparkplug hole Dont torque more then you can with 2 fingers.
hold the compression tester
push the gas pedal to the ground
push clutch in
turn motor over 5 times
record and compare.
The key is to look for consistent results.
good compression is when they are all the same +- 10PSI
for even MORE accurate results, remove your intake. I choose not to because it doesnt change much. Your mostly looking for consistancy. High #'s are just bragging rights
let car COMPLETELY cool before putting back the spark plugs, otherwise you risk a higher chance of stripping the spark plug thread.
torque to 12ft/lbs
hpi247
Aug 1, 2007 10:43 AM
guymosiris
Mar 31, 2007 12:45 PM
zracer240
Apr 24, 2005 08:35 AM
wm5holla
Mar 23, 2003 03:39 PM
smslude
Feb 25, 2003 10:40 AM
