HELP car wont rev past 2k rmp PLEASE help
Old Jun 21, 2003 | 01:54 PM
12SecHatch's Avatar
Default HELP car wont rev past 2k rmp PLEASE help
the car has been sitting for a a lil under 1 year with it beeing started and drivin only a few times. but the car has been being daily driving for a lil over the last month, im not sure with the motor not of being used for over a year it has anything to do with it
94 del sol with a 94 ls motor
its not my car its a friends
ok he drove it last night and as soon as he started to race it it wouldnt go past 6krpm
then so on and so on all the way down to 2krpm is where it sits on the side of the street now
the oil was changed before it started messing up
my friend called me up and i went over there and changed a couple things to see if it would work but nothing helped . some of these items may be stupid, but im no honda expert
put new spark plugs and wires
changed out the injectors
changed the distributor
and chaged out the ecu, but not sure if the ecu would of been able to tell i put in jdm b16 in there, just to see if it would effect it at all but it didnt
its now making a loud hising noise,the noise is not coming from the throttle
is there anyone thing else i should do??????????
please help !!!!
engine codes 15 AND 16
Modified by 12SecHatch at 4:19 PM 6/21/2003
Old Jun 21, 2003 | 01:59 PM
TeStUdO's Avatar
loud hissing noise?? is there an erratic idle?? sounds like a vacuum leak
Old Jun 21, 2003 | 03:07 PM
12SecHatch's Avatar
Default Re: (TeStUdO)
the hissing noise sounds liek its coming from where the header is, i know it sounds weird
i have no clue
i though of vacume leak to but couldnt find anything
is there any vacum leak thta could casue ur rpm not to go up at all
there is a bit of shaking when i rev the motor to 2k it shakes ALOT
Old Jun 21, 2003 | 03:12 PM
EKweezy's Avatar
Default Re: HELP car wont rev past 2k rmp PLEASE help (12SecHatch)
have you checked the timing yet to see if the belt jumped any teeth, from my experience, i know for sure if the timing is off a lil bit, you can drive the car, but t won't rev past 3 k and dies the second you try to floor it,
Old Jun 21, 2003 | 03:17 PM
12SecHatch's Avatar
Default Re: HELP car wont rev past 2k rmp PLEASE help (EAZY)
the exact last thing i said after 4 hours of messing with the car was dod u break any belts or do they fall off?
we looked but the cover was on so i couldnt see the timing belt, well check though
Old Jun 21, 2003 | 03:18 PM
12SecHatch's Avatar
then engine codes its shooting out is
15 , 16 , 41
15 is like for ignition
16 for like fule injection
41 is the o2 censor but thats been on for a long time
Old Jun 21, 2003 | 03:35 PM
EKweezy's Avatar
take off the valve cover and the platic cover covering the cam pulley, turn the crank and line up the white mark and use a ruler to make sure the the marks on the cam pulley lines up straight form one end to the middle to the other end,
code 15, the igniter in the distrubtor its prolly bad
can't help you with code 16, never had a prob. with that
Old Jun 21, 2003 | 04:21 PM
12SecHatch's Avatar
ok, home it worx
anyone else know of anything?
Old Jun 23, 2003 | 11:47 PM
12SecHatch's Avatar
a mechanic , i dont know what mechanic he took it to says the timing is fine
but the compression is off
have no clue
Old Jun 24, 2003 | 05:15 AM
speedymon's Avatar
If its' spitting out those kind of codes then it might be in limp mode. I don't know for sure. Clear up those codes and reset the computer. At least the car is giving you a hint.
dullboy01
34
Nov 29, 2009 07:14 AM
eclipsed95
Jan 13, 2008 05:30 PM
TURBO DC2
Sep 22, 2005 09:44 AM
Nifty
25
Feb 4, 2004 04:01 AM
