single wire alternator
Old Jun 21, 2003 | 10:39 AM
civic disobedience's Avatar
Default single wire alternator
I need to get a single wire alternator for my B16 EG. I am only running engine management, and tail lights, so I should be fine with a 50 amp. what brands do you recommend? who on HT sells them??
Old Jun 21, 2003 | 11:10 AM
PPLH8R's Avatar
Whats wrong with the factory alt ?
Old Jun 21, 2003 | 11:22 AM
Default Re: (AZFAB)
nothing wrong with it, but I am rewiring the whole car, or more like dewiring, I am installing DFI, and removing the entire harness since the DFI comes with its own, so I want to put a single wire setup in and be done with it, is there a way I can modify the stock alt to operate single wire??
Old Jun 21, 2003 | 12:50 PM
PPLH8R's Avatar
Yes you can remove all the wires and make it a one wire alt, no problem. When you are finished you will actually have two wires, one that is the main power that will charge the battery and the other is just re routed to the output wire on the alt. Tell me what year alt you have and I can tell you exactly what you need to do.
Old Jun 21, 2003 | 12:55 PM
SIXTYdashONE's Avatar
HT's Biggest Loser
Default Re: (AZFAB)
Yep, he is right, i just have the one wire on mine also, even tho i still use all my stock harness (except injectors) and taillights, ect..
Old Jun 21, 2003 | 03:44 PM
Default Re: (SIXTYdashONE)
the car is a 92 civic cx, but the motor is a 93 JDM b16A 2nd gen. I didnt do the swap, so I am not sure what alt. is in the car. it was obd1
Old Sep 7, 2003 | 07:39 PM
Almost's Avatar
Default Re: (civic disobedience)
I'm attempting to do this on my b16a first gen obd0 alternator right now...... which prong do i use for the wire?
Old Sep 7, 2003 | 07:58 PM
HT's Biggest Loser
Default Re: (TroyA)
The single wire should be Black/Yellow. It should be the top Right wire (theres 4) . Thumb Release side is the top
Old Sep 7, 2003 | 08:10 PM
Almost's Avatar
that one goes to the ground then goes back to the battery right?
at least that's what the conversion on my mechanics prelude looked like...
Old Sep 7, 2003 | 08:20 PM
IMALLSLO's Avatar
Default Re: (TroyA)
10mm post wire (white thick gauge)goes to 12v constant and the blk/yellow wire to to 12v ingition(key ignition).
Old Sep 7, 2003 | 08:22 PM
HT's Biggest Loser
Default Re: (proclassracer)
Thanks Chris... I was in a rush before and forgot to mention the black/yellow was to the 12v ingition.
Old Sep 7, 2003 | 08:29 PM
Almost's Avatar
so basically blk/yel to the ignition and the white to the battery and I'm set. (i've abandoned all the other wiring in favor of a engine management system, so no eld or ecu to worry about.)
Old Sep 7, 2003 | 09:13 PM
earl's Avatar
Default Re: (TroyA)
That is what we used
Old Sep 8, 2003 | 06:29 AM
Almost's Avatar
Default Re: (earl)
thanks guys
user 20002452454
Dec 8, 2021 03:58 AM
Ty Calkins
Aug 8, 2012 10:40 AM
atxsir
Dec 17, 2006 02:45 PM
elmalouno
Aug 10, 2004 02:44 PM
