IAB wiring
Old Jun 21, 2003 | 09:49 AM
SlackerX's Avatar
Default IAB wiring
There are two wires that come out of the IAB on my gsr motor. Do both of them plug into the ecu?
Old Jun 21, 2003 | 10:04 AM
92SiB18C1's Avatar
Default Re: IAB wiring (SlackerX)
They came off the small plug right? If I remember correctly when I did my swap. One is go to 12 v power, the other is to the ECU.
Old Jun 21, 2003 | 10:06 AM
SlackerX's Avatar
I thought one went to a ground and one the ecu? But where should I ground it if thats the case? Or hook it to 12v power?
Old Jun 21, 2003 | 10:09 AM
92SiB18C1's Avatar
Default Re: (SlackerX)
I'm pretty sure it's to 12 volt source when you turn on the car. Just find a source that have 12 volt when you turn the key. I hook it up to my stereo wiring that gives 12 volt when I turn the key. If i'm not mistaken, it's the yellow/black wire. Double check becuz it's been 1 year.
Old Jun 22, 2003 | 01:38 PM
SlackerX's Avatar
Can anyone confirm this?
Old Jun 24, 2003 | 03:06 PM
Turbo(less)DB8's Avatar
yep. yellow/black to 12v, red/blue to a17. I spliced the yellow/black into the sensor lead wire which is in a25. hope this helps
Modified by nscivic at 5:21 AM 6/25/2003
Old Dec 21, 2003 | 12:30 AM
ph8ed4life's Avatar
Default Re: (nscivic)
Cool, This helps me alot!! I'm doing an h22a4 in my 92 prelude s, and needed the wiring for the iab. Thanks again!!!!
91crxturbo
Aug 19, 2009 03:32 PM
lshatch1.8
Sep 15, 2006 11:03 AM
smnowell
20
Oct 21, 2003 10:28 AM
43MA
Feb 24, 2003 09:40 AM
Alstare
Sep 25, 2002 09:11 PM
