TURN Signal bulbs?
what are the sizes number's? also did anyone come close to matching them?
i have one idea but dont' know if it'll work....to goto the junkyard and get extra 194 light harness thing....and just wire it soo it uses the two lil bulbs anyone know if that works?
not exactly sure what you're asking, but the front turn signal has two bulbs: 1157 and 168. 168 seems to be interchangeable with 194. any OEM-type sidemarker with use a 168/194. i've seen 168 and 194 bulb harnesses at some auto parts stores. i have 4 bulbs per side: turn 1157&168, side 168, and replaced high beam(9005) with 168. there's a wattage limit: i can't run all four bulbs when i have a super high wattage 1157 in (35w, i think). hope that helps. p.s. side is tapped into turn signal's 168 wires.
