Is there fluid in Motor mounts?
Old Jun 20, 2003 | 08:06 PM
ModlesSI's Avatar
New User
Default Is there fluid in Motor mounts?
Wondering if there is suppost to be fluid in the motor mounts. Recently, some sort of fluid has been spraying out onto the bottom of my hood over the driver side top motormount, powersteering area of the engine bay. The fluid is black and stains the bottom of my hood... it isn't oil or powersteering fluid. This is really confusing me... there seems to be no leaks either.... just every few days, there will be new sprays of this liquid under my hood. please help.
thanks in advance
Old Jun 20, 2003 | 08:33 PM
the DR.'s Avatar
Default Re: Is there fluid in Motor mounts? (ModlesSI)
edit:
sorry i stand corrected, i found a pic and the engine mount certainly is fluid filled (not very aquainted with 96+ civics)
Modified by SlicedBread at 9:59 PM 6/20/2003
Old Jun 20, 2003 | 08:45 PM
ModlesSI's Avatar
New User
Default Re: Is there fluid in Motor mounts? (SlicedBread)
Hrm, one guy says that there is fluid.. in my post in the civic forum.
Well, i have checked all the lines in that area very carefully... and nada. Also this fluid does not resemble powersteering fluid or oil. It is thinner than oil and black. I wiped away the spray on my hood, but it still leaves a black stain.
thanks for the response
Old Jun 20, 2003 | 09:58 PM
advanracing62's Avatar
yes, your timing belt upper mount is filled with a fluid... you can get a urathane replacement mount for it if you wish... sounds like it's time to replace your mount either way.
Canucksfan101
Feb 2, 2015 10:05 AM
Bad_dude
May 27, 2008 11:16 AM
Thunder Cat
Dec 9, 2005 03:39 AM
ModlesSI
15
Dec 6, 2004 04:09 AM
speedymon
Aug 27, 2002 05:35 PM
