Urgent Help needed on B16A1 wiring problem!!!!!!
Old Jul 23, 2001 | 02:29 PM
uk99civicvti's Avatar
New User
Default Urgent Help needed on B16A1 wiring problem!!!!!!
Please can anyone help? My mate (Maz) has just put in a B16A1 in the place of his standard ZC in his Jap import '91 CRX. He has bought a Place Racing wiring loom converter, and has found every plug except the 'Knock sensor' wire! He has connected everything except this. The engine turns over but won't start! Does anybody know what the knock sensor does? Would it prevent the engime from starting? What else should he be checking if the engine turns over but doesn't start? Thanks for your help, Matt!!
p.s. Please please help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!11
Old Jul 23, 2001 | 02:51 PM
RyanR's Avatar
Default Re: Urgent Help needed on B16A1 wiring problem!!!!!! (uk99civicvti)
The knock sensor has nothing to do with the engine starting. All it does it detect knock, if it does then it just retards the timing. Are you getting any ECU codes? Are you getting spark and fuel?
Old Jul 23, 2001 | 03:22 PM
raene's Avatar
What he said. The absence of the knock sensor will probably put the engine into limp mode, but it should still start.
How easily does it turn over? Does it TRY to start? Is there fuel and spark?
Old Jul 24, 2001 | 09:01 AM
RyanR's Avatar
Default Re: Urgent Help needed on B16A1 wiring problem!!!!!! (raeneshadow)
No, even if there is no knock sensor it won't go into limp mode, just throw a code.
Old Jul 31, 2001 | 08:39 AM
B16A1-EF9's Avatar
Default Re: Urgent Help needed on B16A1 wiring problem!!!!!! (97TypeR_9)
Normally with older cars I found that when doing the conversion, the fuel pumps tend to go. Check to see if your getting fuel.
ram0869
Jul 23, 2008 02:10 PM
s_vares
Sep 3, 2006 02:54 PM
xwade01
Mar 17, 2005 09:53 AM
d16y8coupe
Nov 22, 2002 02:09 PM
uk99civicvti
Jul 30, 2001 11:32 PM
