do i need to grease anything when replacing release bearing and clutch?
Old Jun 19, 2003 | 09:35 PM
crx1856's Avatar
Default do i need to grease anything when replacing release bearing and clutch?
as title states.
Old Jun 19, 2003 | 10:07 PM
sporkcrx's Avatar
Default Re: do i need to grease anything when replacing release bearing and clutch? (crx1856)
If I remember right, you grease the inside of the pilot bearings and the shaft coming out of the transmission.
Old Jun 19, 2003 | 10:38 PM
Moe's Avatar
Moe
Default Re: do i need to grease anything when replacing release bearing and clutch? (sporkcrx)
Yes you need to grease the imput shaft, where the release bearing slides on, the inside of the release bearing, take the throw out fork out, and becareful theres a small ball you dont want to lose that.
Grease where the fork touches the throw out bearing, and where the ball pivots on the fork. Thats what i did, anything that moved got greased.
http://www.c-speedracing.com has a clutch install on their site.
Old Jun 20, 2003 | 08:34 AM
drumking15's Avatar
Default Re: do i need to grease anything when replacing release bearing and clutch? (Moe)
to a kid who knows where to grease!!!
Old Jun 20, 2003 | 08:42 AM
94CivicSi's Avatar
Default Re: do i need to grease anything when replacing release bearing and clutch? (drumking15)
don't forget the little ball on the end of the slave cylinder.
Pbanto
Apr 8, 2009 05:07 AM
spens 91 Ef
29
Mar 8, 2009 08:15 AM
litterbox
14
Jul 20, 2005 11:33 AM
JFG Kevin
Jun 23, 2005 01:44 PM
Wes V
22
Oct 25, 2003 12:51 PM
