What is the interchange on 5th gen base 5 spd ecus?
Old Jun 19, 2003 | 09:30 PM
pewbert's Avatar
Default What is the interchange on 5th gen base 5 spd ecus?
Bought a write off 98 for $5000. There is a lot of minor body damage all over the car, and left front suspention damage.
My problem is that the ecu and the steering column are gone. I was told that a 97 ecu wont work, but 98-01 are interchangable. I called a few dealers and found that the part numbers are different. I was only able to locatea 00 with a coded key. Can anyone tell me if it will work in the 98? There are no refunds or returns if I buy the 00 ecu and key.
Thanks for the help.
Old Jun 19, 2003 | 09:34 PM
sharkcohen's Avatar
Default Re: What is the interchange on 5th gen base 5 spd ecus? (pewbert)
A 2000 ecu will work. I know of no reason why a 97 ecu would not work.
Old Jun 20, 2003 | 05:03 AM
rjr162's Avatar
Default Re: What is the interchange on 5th gen base 5 spd ecus? (sharkcohen)
if a 98 works a 97 should right? Ignore the fact that all 96+ are OBD-II, the 97 & 98 models are identical, while the 99 & up are identical... with only minor changes between those two groups
navin
Canada (Sales)
Jan 22, 2014 01:54 PM
boostinb18c1
Oct 24, 2011 01:15 PM
nuke1979
Mar 10, 2008 07:01 AM
Red Andy
Feb 9, 2005 04:57 AM
RoaringTurtle
Dec 24, 2002 01:23 PM
