How do I remove primer that was overspray on my car?
Old Jun 19, 2003 | 07:34 PM
Poop111444's Avatar
Default How do I remove primer that was overspray on my car?
Hehe well to make a long story short on my trunk there is some spray of primer on top of my paint.
Is there some chemical that will take it off, yet leave my paint unharmed?
Thanks
Old Jun 19, 2003 | 07:39 PM
KEVlN's Avatar
New User
Default Re: How do I remove primer that was overspray on my car? (si_mekanik)
some say gasoline will work. shouldnt harm your paint, if you wash it off afterwards, and apply some wax. you could of course wet sand it, but that takes a little more knowledge.
turbob18a1's Avatar
clay magic ask a detail shop! do not put gasoline on your vehicle!!!!
Old Jun 19, 2003 | 07:48 PM
IntEGNYC's Avatar
Default Re: (turbob18a1)
clay bar and detailing spray for lubing the clay.
Old Jun 19, 2003 | 07:49 PM
KEVlN's Avatar
New User
I highly doubt a clay bar will work. Don't just pour the gasoline straight onto the car. Lightly damp a rag, and rub it off. As long as you don't rub too hard, it shouldn't make it passed your clear coat, in turn not affecting the paint. This is just what I have read on HT. Ask Emerica.
Old Jun 19, 2003 | 08:19 PM
kkim's Avatar
how bad is the overspray?
Clay bar should work the best for this as this is what it was originally used for... to remove overspray.
you can use the bar with detailing spray or I just like to use a soap and water solution as the lubricant. Make sure you wash your car before using the clay bar. Then when the car is clean, use the soap and water solution along with the claybar to remove the overspray. Rinse the car when you're done and the overspray should be gone and the paint as smooth as glass. Follow up with some wax and you should be very pleased with the results.
good luck
Old Jun 19, 2003 | 08:46 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: (KEVlN)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KEVlN &raquo;</TD></TR><TR><TD CLASS="quote">I highly doubt a clay bar will work. Don't just pour the gasoline straight onto the car. Lightly damp a rag, and rub it off. As long as you don't rub too hard, it shouldn't make it passed your clear coat, in turn not affecting the paint. This is just what I have read on HT. Ask Emerica.</TD></TR></TABLE>
I'm always using gasoline to remove overspray on my car(s).
Has anyone ever spilled gas on their car after filling up???? I do about every time I get gas. It will not harm the finish if it is wiped up or washed off sometie in the near future.
Just damp a rag, like stated above....should work fine.
Or, you could buy paint thinner, etc, but most people have gas just sitting in the garage
Old Jun 19, 2003 | 08:48 PM
Poop111444's Avatar
Default Re: (Emerika)
Where do I get a claybar? The overspray is not that much, just kinda "shimmered" on a bit.
Old Jun 19, 2003 | 09:29 PM
iam7head's Avatar
Default Re: (si_mekanik)
blue clay or clay bar, kragen have those
CblP s40
Detailing
13
Dec 13, 2010 01:39 PM
dtran002
Paint and Body
Nov 10, 2007 01:54 PM
iperez
Dec 7, 2003 04:39 PM
philibuster
Sep 24, 2003 09:28 AM
HaRrYbOy
May 22, 2003 04:59 PM
