cel jumper in 4th gen?
Old Jun 19, 2003 | 04:14 PM
littledan's Avatar
Default cel jumper in 4th gen?
i know this has been covered before but i couldn't find the info i need using search. just want to know if someone has a picture out of a helms of where the connector that i need to jumper is for checking the code for my cel. also what is the method? thanks guys.
dan
Old Jun 19, 2003 | 07:03 PM
JTCdudeman's Avatar
Master H Technician
Default Re: cel jumper in 4th gen? (littledan)
no picture, but its located behind the center console.. connected on the metal frame of the console and will unlcip.. Theres 2 connectors not hoked up at all.. You will see it ez... Its blue.. 2 hole connector.. To jump it, simply put a paper clip or wire in the two holes.. turn car to on position and wait for light to flah.. long= tens, short=ones... Turn car off before unjumping for ecu fryin purposes!
Old Jun 19, 2003 | 11:56 PM
littledan's Avatar
Default Re: cel jumper in 4th gen? (JTCdudeman)
awesome... thanks
crank.it
Nov 11, 2007 04:03 PM
FadedEpic
Feb 2, 2005 09:36 PM
littledan
Jun 5, 2003 03:12 PM
symba
Sep 3, 2002 02:04 PM
clean
Aug 14, 2001 08:35 AM
