my engine bay - grounding kit installed
Old Jun 19, 2003 | 03:13 PM
Loveless's Avatar
Default my engine bay - grounding kit installed
Seems like some people install every cable to the battery terminal while the alternative is to daisy chain it.
Here is my install: daisy chain style
cable 1: battery negative terminal to transmission
cable 2: battery negative terminal - intake manifold
cable 3: intake manifold - alternator
cable 4: intake manifold - radiator mount/chasis
cable 5: radiator mount/chasis - cylinder head
old cable 1: battery negative terminal - chasis near passenger side
old cable 2: valve cover - chasis near radiator on driver side
Old Jun 19, 2003 | 03:25 PM
tilt's Avatar
Default Re: my engine bay - grounding kit installed (Loveless)
nice. so do you think it was worth it? any performance increase?
Old Jun 19, 2003 | 03:31 PM
Loveless's Avatar
Default Re: my engine bay - grounding kit installed (tilt)
I don't feel ****, haha
I don't expect it to anyways.
Old Jun 19, 2003 | 04:00 PM
fubar's Avatar
Did you make it yourself and did you buy it from somewhere?
Old Jun 19, 2003 | 04:02 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
I think it's better to run them all to the battery, but that's just me.
Also your valve cover ground should go on one of the actual bolts near the front edge, not on the timing belt cover.
Old Jun 19, 2003 | 04:21 PM
SilverDc2's Avatar
Default Re: my engine bay - grounding kit installed (PatrickGSR94)
u didn't do the engine to chassis......yea the end doesn't go to the top of the valave cover is goes on the other ones.....if you have audio system you'll feel a difference.
Old Jun 19, 2003 | 04:24 PM
Loveless's Avatar
Default Re: my engine bay - grounding kit installed (SilverDc2)
check between engine and short ram, I connected cylinder head to chasis, unless I did it wrong?
Old Jun 19, 2003 | 05:02 PM
DK4200's Avatar
you should get a ground strap for 5.00 for the valve cover to the front, where that ugly orange wire is, i have one on mine, check out my webpage for pic
good job by the way!!
Old Jun 20, 2003 | 01:40 AM
Loveless's Avatar
Default Re: my engine bay - grounding kit installed (DK4200)
what;s the point of having that? it looks like a sheet of braided metal
better ground?
btw you have a lot of people hating on you according to your guestbook
Old Jun 20, 2003 | 02:37 AM
NightRiderS2K's Avatar
In-N-Out Burger
the real ground straps which sell for nearly over $100 do increase HP in some cars... ive read an article way back when....
loveless: that humoured me how you mentioned people hating on him in his website gbook
no offense to anyone.
CHEERS
NRG
Old Jun 20, 2003 | 04:32 AM
Loveless's Avatar
Default Re: my engine bay - grounding kit installed (NightRider-gsR)
it's very interesting ain't it?
teach me not to make a website about my car
Old Jun 20, 2003 | 07:59 AM
ArizSun21's Avatar
From: Do I look like Michael Bolton from Office Space,, MD, USA
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SilverDc2 &raquo;</TD></TR><TR><TD CLASS="quote">u didn't do the engine to chassis......yea the end doesn't go to the top of the valave cover is goes on the other ones.....if you have audio system you'll feel a difference.</TD></TR></TABLE>
Is that the only wire that makes a difference for an audio system?
Old Jun 20, 2003 | 12:19 PM
DK4200's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Loveless &raquo;</TD></TR><TR><TD CLASS="quote">what;s the point of having that? it looks like a sheet of braided metal
better ground?
btw you have a lot of people hating on you according to your guestbook</TD></TR></TABLE>
yes it does serve as a better ground. I suggested it because you did the whole grounding kit. As far as my guestbook, i really could careless... if i did care then i would delete them, i think it is funny to see what people have to say, half those people probably don't even have a car anyways, or if they do its a peice of ****!!!!!! its all good
Old Jun 20, 2003 | 12:34 PM
JDMjames's Avatar
My friend installed the Hyper Ground Kit from Sun Auto and It actually works. We noticed that the car starts up better, the HIDs on his car got a bit brighter and the stereo sounds cleaner. The kit he got was the silver series one from Sun auto and it has gold plated ends on it. I think it looks cooler than the amount of performance you get from it.
Old Jun 20, 2003 | 12:46 PM
Mikey's Avatar
Default Re: my engine bay - grounding kit installed (JDMjames)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMjames &raquo;</TD></TR><TR><TD CLASS="quote">My friend installed the Hyper Ground Kit from Sun Auto and It actually works. We noticed that the car starts up better, the HIDs on his car got a bit brighter and the stereo sounds cleaner. The kit he got was the silver series one from Sun auto and it has gold plated ends on it. I think it looks cooler than the amount of performance you get from it. </TD></TR></TABLE>
I hope he tuned NAWZ timing too.
Old Jun 21, 2003 | 05:26 AM
In-N-Out Burger
Default Re: my engine bay - grounding kit installed (Mikey)
You're a pretty funny guy Mikey........
NOT! for flaming.
even though, JDMjames is new to this board (welcome BTW), I believe him.
I've read articles about it...
HAVE YOU?
cheers
NRG
Old Jun 21, 2003 | 08:56 AM
closedhood97's Avatar
you know this grounding kit thing is getting ou of hand. This is my point take it or leave it. Your spark plugs use electricity. In order for electricty to flow it must go in a loop. It starts at the battery wich is grounded flows to the item say your stereo which is grounded it flows in a loop. Well the ground on your spark plugs is the threads which hit the head which should be grounded to the frame like that battery. If you ground suck s like the stock one does than you are not getting full spark. Anyone that has messed with high power amplifiers knows that alot of performance can be gained by making sure you ground is absolutelt bare metal and perfect. Same for you engine and there is no way the stock grounding straps are worth a ****. I think there is benefit in this mod just based on the priciples of electricity.
Old Jun 21, 2003 | 11:36 AM
KitKat's Avatar
amazing man you must be James Bond
DrDenby
Honda Civic (2001 - 2005)
Jul 6, 2015 07:13 AM
MarkM01
Apr 25, 2011 05:02 AM
dgerej2
Sep 9, 2009 07:31 PM
Metal Head
Audio / Security / Video
Mar 15, 2009 07:21 AM
