tranny or clutch gone?
Old Jun 19, 2003 | 08:51 AM
andrewasf77's Avatar
Default tranny or clutch gone?
today i go out to start the car and the clutch feels very soft. much softer than usual. the car starts fine, but wont go into gear. it will go into gear with the car turned off, help me out, any ideas?
Old Jun 19, 2003 | 08:54 AM
Big Phat R's Avatar
Default Re: tranny or clutch gone? (andrewasf77)
that's a clutch problem - probably pressure plate.
did you have problems before?
Old Jun 19, 2003 | 08:55 AM
Default Re: tranny or clutch gone? (Big Phat R)
nothing, this is totally out of the blue. no grinding or anything
Old Jun 19, 2003 | 09:11 AM
could it be that the fluid is low? anyone got an easy way to fill tranny fluid?
Old Jun 19, 2003 | 09:24 AM
.RJ's Avatar
.RJ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by andrewasf77 &raquo;</TD></TR><TR><TD CLASS="quote">could it be that the fluid is low? anyone got an easy way to fill tranny fluid?</TD></TR></TABLE>
tranny fluid? unless its leaking, not the cause.
did you check the clutch fluid reservoir? If its empty, this will cause it. If its full, your clutch is busted.
Old Jun 19, 2003 | 09:41 AM
Default Re: tranny or clutch gone? (.RJ)
well, well, well, the reservoir is empty, so on me. i can use dot3-4 brake fluid, correct? this sunday i think i will change all my fluids, sound like fun, anyone wanna help??
Old Jun 19, 2003 | 09:43 AM
Dave-ROR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by andrewasf77 &raquo;</TD></TR><TR><TD CLASS="quote">well, well, well, the reservoir is empty, so on me. i can use dot3-4 brake fluid, correct? this sunday i think i will change all my fluids, sound like fun, anyone wanna help??</TD></TR></TABLE>
lol that or a bad slave would have been my guess. yeah, bleed it out using some dot 4 brake fluid. the bleeder is on the slave cylinder.
Old Jun 19, 2003 | 10:25 AM
Default Re: tranny or clutch gone? (dawhiteboy)
the slave cylinder being to the left of the exh. man.? its a 8mm socket, right?
Old Jun 19, 2003 | 10:36 AM
.RJ's Avatar
.RJ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by andrewasf77 &raquo;</TD></TR><TR><TD CLASS="quote">the slave cylinder being to the left of the exh. man.? its a 8mm socket, right?</TD></TR></TABLE>
well if its out of fluid, fill it and bleed the slave cylinder. keep an eye on the fluid level, use cheap-o DOT3 brake fluid.
Old Jun 19, 2003 | 10:54 AM
do i have the right bleeder?
Old Jun 19, 2003 | 11:04 AM
.RJ's Avatar
.RJ
well there's a bleeder on the slave cyl, looks just like the brake bleeder. Or you could order a speed bleeder for it ( http://www.speedbleeder.com/ ) and save yourself alot of hassle
Old Jun 19, 2003 | 11:21 AM
just to be sure it is the small 8mm bolt on a little pipe, just unscrew that and pour the fluid in the reservoir and let gravity take over?
Old Jun 19, 2003 | 11:29 AM
.RJ's Avatar
.RJ
do a search for clutch bleed/bleeding, you'll find instructions there - fill up the reservoir before you start. Just keep an eye on the fluid level. My old SC had this problem (leaky slave) and i checked the fluid level at each oil change and topped off as neccessary, drove it for 5 years like that.
Old Jun 19, 2003 | 11:33 AM
thanks, will do
Old Jun 19, 2003 | 11:53 AM
Dave-ROR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by andrewasf77 &raquo;</TD></TR><TR><TD CLASS="quote">just to be sure it is the small 8mm bolt on a little pipe, just unscrew that and pour the fluid in the reservoir and let gravity take over?</TD></TR></TABLE>
8mm sounds right, and yes, it looks just like the brake bleeders. To bleed, you'll need to pump the clutch pedal to move the fluid through the system.
Old Jun 19, 2003 | 12:25 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dawhiteboy &raquo;</TD></TR><TR><TD CLASS="quote">
8mm sounds right, and yes, it looks just like the brake bleeders. To bleed, you'll need to pump the clutch pedal to move the fluid through the system.</TD></TR></TABLE>
so the gravity technique wont work, i read that in another post
Old Jun 19, 2003 | 02:34 PM
AllmotorJunkie's Avatar
check your throw out bearing?
Old Jun 19, 2003 | 03:33 PM
Default Re: tranny or clutch gone? (AllmotorJunkie)
thanks to those who helped out today. i think the problem is fixed, for now. i bled out all the old fluid, it was pretty gunky and really thick (like motor oil). anyway, the car shifts just as it did so i am happy. i will keep an eye on the fluid very closely for the next few days to ensure there are no other leaks. rest assured, if there are, H-T will be the first to know.
Old Jun 19, 2003 | 07:20 PM
ITR#132's Avatar
look for a source to where your fluid went. There should be no reason it is empty unless its leaking. Check your clutch Master cylinder for leakage (Inside the car above the clutch pedal, if theres brake fluid all around its time to replace it)
Old Jun 19, 2003 | 07:32 PM
People_Mover's Avatar
From: HT PRO POKER PLAYER IM FOR FREE STARTUP, MONEY
Default Re: (ITR#132)
Andy you are sofa king we-todd-did
DC5Danny
Jan 21, 2008 08:36 AM
fanta!
12
Dec 30, 2005 06:59 AM
s2kkid
Oct 17, 2005 08:09 PM
turbotime
29
Oct 3, 2004 10:00 PM
