Ignition Problem. Please HELP!!!
Old Jun 18, 2003 | 08:36 PM
92TEGsrSC's Avatar
Default Ignition Problem. Please HELP!!!
Here's the situation.... Every once in a while--- and ONLY every once in a while, I will turn the key of my car and I hear a click-- but nothing happens... the engine doesn't crank like it's trying to start or anything... I thought it was the battery--- so I just replaced that today... I thought it fixed the problem-- but NOPE... it happened again... it won't start... then I'll wait a few minutes and try again... and it still won't start... then I try again... eventually it'll start..... could this be a problem w/ the ignition coil??? it doesn't seem like it could be--- because usually if the ignition coil is bad the car won't start at all... regardless of attempts. Once the car is started, it runs fine... Can someone please tell me what's wrong with my car???
Thank you in advance for all help.
Zack
Old Jun 18, 2003 | 08:50 PM
poison's Avatar
Default Re: Ignition Problem. Please HELP!!! (92TEGsrSC)
No cranking, and doing it intermitantly is a sign of a faulty Starter Solenoid.
I would remove the starter, and do a bench test or take it to an Auto store to have it tested.
Sounds like the Starter Solenoid is going out. A replacement starter should fix this problem.
Old Jun 18, 2003 | 09:15 PM
92TEGsrSC's Avatar
how much does a new starter cost for a GSR or any Integra? Just wondering--- I'll probably do this tomorrow--- I owe my parents money and am just about out of debt--- this shouldn't set me too much into debt-- should it
runitup
21
Dec 26, 2020 05:17 PM
everlight44
Feb 7, 2009 11:35 AM
soto2635
Jan 15, 2009 10:44 AM
NACvicSi
Oct 17, 2005 06:58 AM
EJ1 wilcox
Apr 25, 2005 02:25 PM
