ef-1 Tech Help
Old Jun 18, 2003 | 02:54 PM
Rocket's Avatar
Default ef-1 Tech Help
GOT QUESTIONS? ef-1 Tech Support can help you.
ef-1 is proud to offer free tech support by our official level 4 mechanic 99Hybrid_Hatch
Engine Building
LSVtec's
Compression ratio calculation
Piston installation and prep
ACL bearing installation
Head studs installation
GSR manifold porting
Hand Honing
HeadAssembly
Spring installation
Cam installation
Lost motion assembly problems
Engine Swap
Wiring
Installation
Tranny / Clutch
B-Series tranny rebuilding
D-Series tranny rebuilding
Quaife installation
Custom gear installation
Clutch installation
Hondata
Tuning
Base map writing
ECU Socketing
Nitrous
Single Fogger
GSR Plate
Jet settings
Turbo
Installation
Down pipe fabrication for differet types of turbine housing
Ceramic coating turbo manifolds
A word about David (99Hybrid_Hatch), David is one of the most talented mechanics I've ever met. Best of all he is very humble and likes to help everyone.
So feel free to take advantage of our offer. We are sincere about helping people and most have found us to be at the least very enlightening.
Click here for David's profile 99Hybrid_Hatch
Thanks.
Old Jun 18, 2003 | 04:54 PM
HYBRID_H@TCH's Avatar
Default Re: ef-1 Tech Help (Rocket)
Thanks Rocket
Iam here if anyone has a issue just let me know and lets see if I can help you out.Iam pretty new to hondata but I might be able to help with some/alot of questions.
so if you need anything just hit me up and I will do my best.
David
ps---> I will post more contact info on friday after my new isp is up and running
Old Jun 25, 2003 | 09:58 PM
junya16's Avatar
Default Re: ef-1 Tech Help (99Hybrid_Hatch)
i got a question about rebuilding my b16 tranny...where is the best place to get a whole new gear/synchro setup and by looking at my setup do u think i should run like may be a gsr first and second or anything like that?
Old Jun 25, 2003 | 10:38 PM
Rob Dizzle's Avatar
Default Re: ef-1 Tech Help (junya16)
haha
i need to ask him about valve spring installation. im on hour 192,228 right now. if its not done tomorrow with a new magic tool I just aquired, then I am going to call him.
Old Jun 25, 2003 | 10:45 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by junya16 &raquo;</TD></TR><TR><TD CLASS="quote">i got a question about rebuilding my b16 tranny...where is the best place to get a whole new gear/synchro setup and by looking at my setup do u think i should run like may be a gsr first and second or anything like that?</TD></TR></TABLE>
I would think your B16 tranny would go good with a all motor high rev gsr..but I dont know of anywhere to get the jdm b16 tranny sync's...I have heard they are the same as "D" series but cant confirm.
Old Jun 26, 2003 | 02:05 AM
Rocket's Avatar
Contact Bob-DC2 he may be able to help you get OE tranny parts for a reasonable price.
You have to change the mainshaft to a GSR mainshaft to get GSR 1st and 2nd gear since they are both directly machined on the main shaft.
It is a little nicer to have a higher first gear to get higher mph out of 1st and less of an rpm drop when shifting into 2nd.
Old Jun 26, 2003 | 11:36 AM
junya16's Avatar
thank you much
Old Jun 26, 2003 | 11:59 AM
ill phil's Avatar
How do I measure the installed height of valve springs? I hear people talk about installed height, how do I check and adjust it? I know with V8 heads I've assembled I would have to shim it, and they were measuring with a caliper style micrometer... but that was in class where I had the tools. Any help would be appreciated. Thanks!
Old Jun 26, 2003 | 12:36 PM
Rocket's Avatar
Default Re: ef-1 Tech Help (ill phil)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ill phil &raquo;</TD></TR><TR><TD CLASS="quote">How do I measure the installed height of valve springs? I hear people talk about installed height, how do I check and adjust it? I know with V8 heads I've assembled I would have to shim it, and they were measuring with a caliper style micrometer... but that was in class where I had the tools. Any help would be appreciated. Thanks!</TD></TR></TABLE>
Without a spring mic it's hard to do. I usually install the valve and retainer with just the stock inner spring (pressue is low enough to easily install by hand). Then carefully cut a drinking straw to 1.320" then use this to gage the distance between the spring seat and retainer where the outer spring seats.
Old Jun 26, 2003 | 01:15 PM
ill phil's Avatar
Ok and a method like this will work with your Speed Stable springs? I should be picking up the cams and everything in the next week or two from camp1320. I do have a caliper type mic that would work to measure, but how do I adjust if its not in spec?
Old Jun 26, 2003 | 02:18 PM
Rocket's Avatar
To adjust the valve up or down will require you to i) change the size of the valve ii) change the valve job.
Typically with our retainer you'll have more than 1.320" as our retainer also sits higher for more lift.
Hopes this helps.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ill phil &raquo;</TD></TR><TR><TD CLASS="quote">Ok and a method like this will work with your Speed Stable springs? I should be picking up the cams and everything in the next week or two from camp1320. I do have a caliper type mic that would work to measure, but how do I adjust if its not in spec?</TD></TR></TABLE>
chrisyaj
May 15, 2008 05:51 PM
onebad91crxlsvtec
Sep 14, 2006 03:53 PM
singlecammajamma
Feb 12, 2005 07:27 AM
stehigs321
Jun 19, 2004 11:43 AM
yaksplat
Aug 16, 2001 08:43 AM
