any tips on painting valve cover?
Old Jun 17, 2003 | 07:25 PM
fast4doorgsr's Avatar
Default any tips on painting valve cover?
i want to paint my valve cover red, will regular spray paint work or should i use engine paint.what will work best, i don't want to spend 150$ on a real red valve cover just spent 3500$ on motor rebuild. some one has to have done this before.what should i cover the VTEC DOHC with cuz i want it to look like a stock type r one.
Modified by fast4doorgsr at 12:11 AM 6/18/2003
Old Jun 17, 2003 | 07:34 PM
teg92's Avatar
Default Re: any tips on painting valve cover? (fast4doorgsr)
run a search for "valve cover" in recent and archived. you will find more than enough information.
Old Jun 17, 2003 | 08:47 PM
Preludeh22a's Avatar
I did mine on my old integra. Just take it off Strip it completely make sure u do that or it will comeout shitty....then just get engine paint do plenty of layers of whatever color then drop a few clear coats on to protect comes out good....
Old Jun 17, 2003 | 11:03 PM
GZR4DR's Avatar
Default Re: (Preludeh22a)
Get the high temp paint. I believe there is a paint that does the ripple finish or whatever and looks somewhat similar to stock. I recommend stripping the old paint off first.
Old Jun 17, 2003 | 11:12 PM
95hbMatt's Avatar
Default Re: (GZR4DR)
read over my post:
https://honda-tech.com/zerothread?id=506725
You can buy VHT red krinkle paint from summittracing.com...use petroleum jelly on the letters when painting then scrape off when done.
Use Aircraft Stripper(paint remover) can be bought from Walmart, to remove the old paint from your valve cover....then clean down with Simple Green and then paint!
5G_Vtec
Mar 14, 2007 06:45 PM
B18C-YA!
Jul 30, 2006 08:46 AM
jsteezy1290
18
May 12, 2004 08:59 PM
RosSi
Jul 7, 2002 10:35 PM
Lookincrazy
Jul 6, 2002 12:52 AM
